    Won't start on windows after upgrade...
    2 Posts 1 Posters 2.1k Views 1 Watching
    • cowboysdudeC
      cowboysdude Module Developer
      1 verbose cli [ 'C:\\Program Files\\nodejs\\node.exe',
      1 verbose cli   'C:\\Users\\John\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
      1 verbose cli   'start' ]
      2 info using npm@3.10.9
      3 info using node@v6.9.1
      5 info lifecycle magicmirror@2.1.1~prestart: magicmirror@2.1.1
      6 silly lifecycle magicmirror@2.1.1~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.1.1~start: magicmirror@2.1.1
      8 verbose lifecycle magicmirror@2.1.1~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.1.1~start: PATH: C:\Users\John\AppData\Roaming\npm\node_modules\npm\bin\node-gyp-bin;C:\MagicMirror\node_modules\.bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\Calibre2\;C:\Program Files\nodejs\;C:\xampp\php;C:\ProgramData\ComposerSetup\bin;C:\Program Files\Git\cmd;C:\Program Files (x86)\Skype\Phone\;C:\Program Files (x86)\Microsoft VS Code\bin;C:\Users\John\AppData\Local\Microsoft\WindowsApps;C:\Users\John\AppData\Roaming\npm;C:\Users\John\AppData\Roaming\Composer\vendor\bin
      10 verbose lifecycle magicmirror@2.1.1~start: CWD: C:\MagicMirror
      11 silly lifecycle magicmirror@2.1.1~start: Args: [ '/d /s /c', 'sh run-start.sh' ]
      12 silly lifecycle magicmirror@2.1.1~start: Returned: code: 1  signal: null
      13 info lifecycle magicmirror@2.1.1~start: Failed to exec start script
      14 verbose stack Error: magicmirror@2.1.1 start: `sh run-start.sh`
      14 verbose stack Exit status 1
      14 verbose stack     at EventEmitter. (C:\Users\John\AppData\Roaming\npm\node_modules\npm\lib\utils\lifecycle.js:255:16)
      14 verbose stack     at emitTwo (events.js:106:13)
      14 verbose stack     at EventEmitter.emit (events.js:191:7)
      14 verbose stack     at ChildProcess. (C:\Users\John\AppData\Roaming\npm\node_modules\npm\lib\utils\spawn.js:40:14)
      14 verbose stack     at ChildProcess.emit (events.js:191:7)
      14 verbose stack     at maybeClose (internal/child_process.js:877:16)
      14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      15 verbose pkgid magicmirror@2.1.1
      16 verbose cwd C:\MagicMirror
      17 error Windows_NT 10.0.14393
      18 error argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\John\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "start"
      19 error node v6.9.1
      20 error npm  v3.10.9
      21 error code ELIFECYCLE
      22 error magicmirror@2.1.1 start: `sh run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
      23 error Make sure you have the latest version of node.js and npm installed.
      23 error If you do, this is most likely a problem with the magicmirror package,
      23 error not with npm itself.
      23 error Tell the author that this fails on your system:
      23 error     sh run-start.sh
      23 error You can get information on how to open an issue for this project with:
      23 error     npm bugs magicmirror
      23 error Or if that isn't available, you can get their info via:
      23 error     npm owner ls magicmirror
      23 error There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      • cowboysdudeC
        Okay if you install git bash from here: https://git-for-windows.github.io/
        Will not work under windows terminal [command window - cmd] window. Install program then right click on desktop and you will see a “Git Bash Here” on that menu. Type your normal ‘npm start’ and the mirror will run.
        Windows does not recognize bash or sh… under git bash it does because it creates a linux like enviroment and runs great.
        Thanks Strawberry… again.
