    • Search
    MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
    Calendar stuck at 'Loading...' after 2.1.1 update
    Troubleshooting
      sithlordhood last edited by yawns
      So since the update I have had nothing but problems, first the black screen on boot (I managed to get rid of this somehow by running ‘git pull && npm install’ for a second time…
      Now however when I boot MM all of the modules load except the Calendar (default module).
      When I boot MM the following log is shown:
      Starting MagicMirror: v2.1.1
      Loading config ...
      Loading module helpers ...
      No helper found for module: calendar_monthly.
      Module helper loaded: MMM-NetworkScanner
      Module helper loaded: MMM-Traffic
      Module helper loaded: mmm-systemtemperature
      All module helpers loaded.
      Starting server op port 8080 ...
      Server started ...
      Connecting socket for: MMM-NetworkScanner
      Starting module: MMM-NetworkScanner
      Starting module: newsfeed
      Connecting socket for: MMM-Traffic
      MMM-Traffic helper started ...
      Connecting socket for: mmm-systemtemperature
      Starting node helper: mmm-systemtemperature
      (node:3999) DeprecationWarning: sys is deprecated. Use util instead.
      Launching application.
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/MY EMAIL/private-MY APIKEY/basic.ics - Interval: 300000
      MMM-NetworkScanner received CONFIG
      Create new news fetcher for url: http://feeds.bbci.co.uk/news/rss.xml?edition=uk - Interval: 300000
      Error: dates lower than Thu Jan 01 1970 00:00:00 GMT+0000 (BST) are not supported
          at Object.toOrdinal (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:105:15)
          at Iterinfo.rebuild (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:1409:35)
          at RRule._iter (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:978:10)
          at RRule.between (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:794:21)
          at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:122:24
          at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:5)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
          at emitTwo (events.js:106:13)
          at Request.emit (events.js:191:7)
          at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1081:10)
      I have downloaded the master file from git and replaced the modules/default on the pi with these but no change.
      I know the calendar url is fine as when I access via web browser it downloads the .ics
      Can anyone help at all?
      strawberry 3.141 1 Reply Last reply Reply Quote 0
      • strawberry 3.141
        strawberry 3.141 Project Sponsor Module Developer @sithlordhood last edited by
        @sithlordhood said in Calendar stuck at ‘Loading...’ after 2.1.1 update:
        see also https://github.com/MichMich/MagicMirror/issues/791
          This has fixed my problem - thanks very much!
          • C
            Chadeus last edited by
            Did you alter the rrule files and set them to 1900 to make them work? I reviewed my Google Calendar private url ics file and it looks like it doesn’t go before 1970. Now when I have MM2 running (2.1.1) it doesn’t give me the 1970 error but continues to show “loading”. Is there a fix for using private url? It works in the previous MM that I have installed on a separate Pi that I have yet to update.
            • C
              Chadeus @Chadeus last edited by Chadeus
              @Chadeus Replying to myself, but wanted this for the community.
              It was about fixing the rrule-alt file and I changed it from 1970 to 1900 per the above link. Specifically: /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js
              Change: ORDINAL_BASE: new Date(1900, 0, 1), /* changed from 1970 to 1900 */
              Also, I generated a fresh private url for my Google Calendar. Not sure if that plays into it or not, but it worked after the changes plus getting a new url.
