    Blank Black Screen - noob
    7 Posts 2 Posters 3.5k Views 3 Watching
      dslucki
      I am running MagicMirror but all I get is a black blank screen. All I have is the default script. I am running on a Pi Zero with WiFi an have used instructions that I found here. When I run node serveronly it runs without any errors. I can connect to it but it is just a blank screen.
      Config.js file is:
      * Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
          port: 8080,
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120" , "192.168.1.6"],
          language: 'en',
          timeFormat: 24,
          units: 'metric',
                  module: 'alert',
                  module: 'clock',
                  position: 'top_left',
                      displayType: 'analog',
                      analogFace: 'face-001',
                  module: 'calendar',
                  header: 'UK Holidays',
                  position: 'top_right',
                              symbol: 'calendar-check-o ',
                              url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
                  module: 'newsfeed',
                  position: 'bottom_bar',
                      feeds: [
                              title: "BBC UK News",
                              url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
                      showSourceTitle: true,
                      showPublishDate: true,
                      showDescription: true,
      Any help is appreciated.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @dslucki
        @dslucki your config looks good, I guess one of these functions uses es6 features which the midori browser doesnt support. You can open the developer console on your browser and see the errors
          dslucki @strawberry 3.141
          @strawberry-3.141 OK, that was a good tip. So here is a screen shot of the inspect in Midori. It is all Greek to me. Anyone have any ideas? 0_1491408290031_upload-4c3ac6bd-72a8-4893-95fd-4582671f22bc
            @dslucki you forgot to do npm install in MagicMirror directory
              @strawberry-3.141 I thought I did that. I ran it again and here is the output
              pi@raspberrypi:~/MagicMirror $ npm install
              npm ERR! Linux 4.4.50+
              npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
              npm ERR! node v4.2.1
              npm ERR! npm  v2.14.7
              npm ERR! path /home/pi/MagicMirror/node_modules/.bin/stylelint
              npm ERR! code EACCES
              npm ERR! errno -13
              npm ERR! syscall unlink
              npm ERR! Error: EACCES: permission denied, unlink '/home/pi/MagicMirror/node_modules/.bin/stylelint'
              npm ERR!     at Error (native)
              npm ERR!  { [Error: EACCES: permission denied, unlink '/home/pi/MagicMirror/node_modules/.bin/stylelint']
              npm ERR!   errno: -13,
              npm ERR!   code: 'EACCES',
              npm ERR!   syscall: 'unlink',
              npm ERR!   path: '/home/pi/MagicMirror/node_modules/.bin/stylelint' }
              npm ERR!
              npm ERR! Please try running this command again as root/Administrator.
              Then I ran it as: sudo npm install
              pi@raspberrypi:~/MagicMirror $ sudo npm install
              npm WARN cannot run in wd magicmirror@2.1.1 cd vendor && npm install (wd=/home/pi/MagicMirror)
              npm WARN cannot run in wd magicmirror@2.1.1 sh installers/postinstall/postinstall.sh (wd=/home/pi/MagicMirror)
                @dslucki you dont have the permission to access, you probably did sudo npm install before and so your normal pi user has restricted access to it.
                try npm install --unsafe-perm
                  @strawberry-3.141 SUCCESS! Thanks.
                  pi@raspberrypi:~/MagicMirror $ sudo npm install --unsafe-perm
                  > magicmirror@2.1.1 install /home/pi/MagicMirror
                  npm WARN package.json magicmirror-vendors@ No README data
                  font-awesome@4.7.0 node_modules/font-awesome
                  moment-timezone@0.5.13 node_modules/moment-timezone
                  weathericons@2.1.0 node_modules/weathericons
                  moment@2.18.1 node_modules/moment
                  > magicmirror@2.1.1 postinstall /home/pi/MagicMirror
                  MagicMirror installation successful!
