    Nobody is ready to Help!!
    16 Posts 6 Posters 9.5k Views 6 Watching
    • U Offline
      undergroundauth
      i am very new to git club and i am trying to install MagicMirror
      unfortunately no one is ready to help
      I want to do this project for my kid and i am unable to do so.
      problem 1- I get this error when i do ‘npm start’ i tried multiple ways i could not get the solution … seems no one to help
      problem 2- I am connected to Raspberry pi 3 model b with HDMI cable connected to my TV
      For the mirror i need to connect to the monitor , i have a LG LED model and i get this error that signal not found
      Please help
      root@raspberrypi:/home/pi/MagicMirror# npm start
      magicmirror@2.1.1 start /home/pi/MagicMirror
      sh run-start.sh
      /home/pi/MagicMirror/node_modules/electron/index.js:9
      throw new Error(‘Electron failed to install correctly, please delete node_modules/’ + path.basename(__dirname) + ’ and try installing again’)
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
      at Module._compile (module.js:570:32)
      at Object.Module._extensions…js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.require (module.js:497:17)
      at require (internal/module.js:20:19)
      at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
      npm ERR! Linux 4.4.50-v7+
      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
      npm ERR! node v6.10.2
      npm ERR! npm v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.1 start: sh run-start.sh
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.1 start script ‘sh run-start.sh’.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! sh run-start.sh
      npm ERR! npm bugs magicmirror
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      U 1 Reply Last reply Reply Quote 0
      • U Offline
        undergroundauth @undergroundauth
        @roramirez - Please Help!!
        • cowboysdudeC Offline
          cowboysdude Module Developer
          U 1 Reply Last reply Reply Quote 1
          • U Offline
            undergroundauth
            @cowboysdude said in Nobody is ready to Help!!:
            Thanks for the response, what command should i run to delete and how do i reinstall it
            Please advise
            • U Offline
              undergroundauth @cowboysdude
              i followed these steps mentioned by you in one of the problems
              git clone https://github.com/electron/electron-quick-start
              cd electron-quick-start
              npm install
              npm start
              electron-quick-start@1.0.0 start PATH\electron-quick-start
              electron .
              the window comes Hello World
              but when i reboot the system it says the same error
                If you are running on a Pi then you have Raspbian installed so you have a file browser.
                go to the MagicMirror folder and delete the node_modules directory and try reinstalling the mirror in a terminal window …
                In the terminal window in the MagicMirror folder type:
                npm install
                U Mykle1M 2 Replies Last reply Reply Quote 1
                • U Offline
                  @cowboysdude -Thanks for the help… it works… i am not able to see the weather on right side… i created an account in openweathermap and added the API key under the config.js.sample file but it does not show… also can you help me to add some of these modules … an example how to add in the config file will help… my kid is really exited to see the mirror working… Thanks
                  hartattackH A 2 Replies Last reply Reply Quote 0
                  • hartattackH Offline
                    hartattack @undergroundauth
                    @undergroundauth said in Nobody is ready to Help!!:
                    Make sure you have the API key and the Location and Location ID in the config.js file.
                    • U Offline
                      undergroundauth @hartattack
                      This post is deleted!
                      hartattackH 1 Reply Last reply Reply Quote 0
                        @undergroundauth
                        Your API key needs to be in quotations “”
                          roramirez Core Contributors @undergroundauth
                          @undergroundauth I think are you missing run
                          npm install
                          Easy module development with MagicMirror Module Template
                            Mykle1 Project Sponsor Module Developer @cowboysdude
                            npm install
                            What he said! (about 6 posts above)
                              roramirez Core Contributors @Mykle1
                              In the electron example app (quick-start) … @Mykle1 ;)
                                Mykle1 Project Sponsor Module Developer @roramirez
                                @roramirez said in Nobody is ready to Help!!:
                                :thumbsup:
                                  Anhalter42 @undergroundauth
                                  @undergroundauth - I don’t know whether the problem is already solved or not. Anyway, since noone mentioned it explicitly, here a note: you should copy/rename config.js.sample to config.js at first since changes to config.js.sample are completely ignored. Only the file config.js is used and so, your changes should only go there.
                                    cowboysdude Module Developer @Anhalter42
                                    This issue was solved.
