    Nobody is ready to Help!!
    16 Posts 6 Posters 8.6k Views 6 Watching
    • U Offline
      undergroundauth
      @cowboysdude said in Nobody is ready to Help!!:
      node_modules/’ + path.basename(__dirname) +
      Thanks for the response, what command should i run to delete and how do i reinstall it
      Please advise
      • U Offline
        undergroundauth @cowboysdude
        please delete node_modules/’ + path.basename(__dirname)
        i followed these steps mentioned by you in one of the problems
        git clone https://github.com/electron/electron-quick-start
        cd electron-quick-start
        npm install
        npm start
        electron-quick-start@1.0.0 start PATH\electron-quick-start
        electron .
        the window comes Hello World
        but when i reboot the system it says the same error
        • cowboysdudeC Offline
          If you are running on a Pi then you have Raspbian installed so you have a file browser.
          go to the MagicMirror folder and delete the node_modules directory and try reinstalling the mirror in a terminal window …
          In the terminal window in the MagicMirror folder type:
          npm install
          U Mykle1M 2 Replies Last reply Reply Quote 1
          • U Offline
            @cowboysdude -Thanks for the help… it works… i am not able to see the weather on right side… i created an account in openweathermap and added the API key under the config.js.sample file but it does not show… also can you help me to add some of these modules … an example how to add in the config file will help… my kid is really exited to see the mirror working… Thanks
            hartattackH A 2 Replies Last reply Reply Quote 0
            • hartattackH Offline
              hartattack @undergroundauth
              @undergroundauth said in Nobody is ready to Help!!:
              Make sure you have the API key and the Location and Location ID in the config.js file.
              U 1 Reply Last reply Reply Quote 1
              • U Offline
                undergroundauth @hartattack
                hartattackH 1 Reply Last reply Reply Quote 0
                  @undergroundauth
                  Your API key needs to be in quotations “”
                    roramirez Core Contributors @undergroundauth
                    @undergroundauth I think are you missing run
                    npm install
                      npm install
                      What he said! (about 6 posts above)
                        roramirez Core Contributors @Mykle1
                        In the electron example app (quick-start) … @Mykle1 ;)
