    Nobody is ready to Help!!
    16 Posts 6 Posters 9.5k Views 6 Watching
    • cowboysdudeC Offline
      Electron failed to install correctly, please delete node_modules/’ + path.basename(__dirname) + ’ and try installing again
      U 1 Reply Last reply Reply Quote 1
      • U Offline
        undergroundauth
        @cowboysdude said in Nobody is ready to Help!!:
        Thanks for the response, what command should i run to delete and how do i reinstall it
        Please advise
        • U Offline
          undergroundauth @cowboysdude
          i followed these steps mentioned by you in one of the problems
          git clone https://github.com/electron/electron-quick-start
          cd electron-quick-start
          npm install
          npm start
          electron-quick-start@1.0.0 start PATH\electron-quick-start
          electron .
          the window comes Hello World
          but when i reboot the system it says the same error
            If you are running on a Pi then you have Raspbian installed so you have a file browser.
            go to the MagicMirror folder and delete the node_modules directory and try reinstalling the mirror in a terminal window …
            In the terminal window in the MagicMirror folder type:
            npm install
            U Mykle1M 2 Replies Last reply Reply Quote 1
            • U Offline
              @cowboysdude -Thanks for the help… it works… i am not able to see the weather on right side… i created an account in openweathermap and added the API key under the config.js.sample file but it does not show… also can you help me to add some of these modules … an example how to add in the config file will help… my kid is really exited to see the mirror working… Thanks
              hartattackH A 2 Replies Last reply Reply Quote 0
              • hartattackH Offline
                hartattack @undergroundauth
                @undergroundauth said in Nobody is ready to Help!!:
                Make sure you have the API key and the Location and Location ID in the config.js file.
                • U Offline
                  undergroundauth @hartattack
                  hartattackH 1 Reply Last reply Reply Quote 0
                    @undergroundauth
                    Your API key needs to be in quotations “”
                      roramirez Core Contributors @undergroundauth
                      @undergroundauth I think are you missing run
                      npm install
                        npm install
                        What he said! (about 6 posts above)
                          roramirez Core Contributors @Mykle1
                          In the electron example app (quick-start) … @Mykle1 ;)
                            Mykle1 Project Sponsor Module Developer @roramirez
                            @roramirez said in Nobody is ready to Help!!:
                            :thumbsup:
                              Anhalter42 @undergroundauth
                              @undergroundauth - I don’t know whether the problem is already solved or not. Anyway, since noone mentioned it explicitly, here a note: you should copy/rename config.js.sample to config.js at first since changes to config.js.sample are completely ignored. Only the file config.js is used and so, your changes should only go there.
                                cowboysdude Module Developer @Anhalter42
                                This issue was solved.
