    Nobody is ready to Help!!
    16 Posts 6 Posters 9.9k Views 6 Watching
    • U
      undergroundauth @cowboysdude
      @cowboysdude said in Nobody is ready to Help!!:
      please delete node_modules/’ + path.basename(__dirname)
      i followed these steps mentioned by you in one of the problems
      git clone https://github.com/electron/electron-quick-start
      cd electron-quick-start
      npm install
      npm start
      electron-quick-start@1.0.0 start PATH\electron-quick-start
      electron .
      the window comes Hello World
      but when i reboot the system it says the same error
      • cowboysdudeC
        If you are running on a Pi then you have Raspbian installed so you have a file browser.
        go to the MagicMirror folder and delete the node_modules directory and try reinstalling the mirror in a terminal window …
        In the terminal window in the MagicMirror folder type:
        npm install
        U Mykle1M 2 Replies Last reply
        • U
          @cowboysdude -Thanks for the help… it works… i am not able to see the weather on right side… i created an account in openweathermap and added the API key under the config.js.sample file but it does not show… also can you help me to add some of these modules … an example how to add in the config file will help… my kid is really exited to see the mirror working… Thanks
          hartattackH A 2 Replies Last reply
          • hartattackH
            hartattack @undergroundauth
            @undergroundauth said in Nobody is ready to Help!!:
            Make sure you have the API key and the Location and Location ID in the config.js file.
            U 1 Reply Last reply
            • U
              undergroundauth @hartattack
              hartattackH 1 Reply Last reply
              • hartattackH
                @undergroundauth
                Your API key needs to be in quotations “”
                  roramirez Core Contributors @undergroundauth
                  @undergroundauth I think are you missing run
                  npm install
                  • Mykle1M
                    npm install
                    What he said! (about 6 posts above)
                    R 1 Reply Last reply
                      roramirez Core Contributors @Mykle1
                      In the electron example app (quick-start) … @Mykle1 ;)
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @roramirez
                        @roramirez said in Nobody is ready to Help!!:
                        :thumbsup:
                        • A
                          Anhalter42 @undergroundauth
                          @undergroundauth - I don’t know whether the problem is already solved or not. Anyway, since noone mentioned it explicitly, here a note: you should copy/rename config.js.sample to config.js at first since changes to config.js.sample are completely ignored. Only the file config.js is used and so, your changes should only go there.
                          • cowboysdudeC
                            cowboysdude Module Developer @Anhalter42
                            This issue was solved.
