    Nobody is ready to Help!!
    16 Posts 6 Posters 7.6k Views 6 Watching
      roramirez Core Contributors @undergroundauth
      @undergroundauth I think are you missing run
      npm install
      Easy module development with MagicMirror Module Template
        Mykle1 Project Sponsor Module Developer @cowboysdude
        @cowboysdude said in Nobody is ready to Help!!:
        In the terminal window in the MagicMirror folder type:
        npm install
        What he said! (about 6 posts above)
          roramirez Core Contributors @Mykle1
          In the electron example app (quick-start) … @Mykle1 ;)
            Mykle1 Project Sponsor Module Developer @roramirez
            @roramirez said in Nobody is ready to Help!!:
            :thumbsup:
              Anhalter42 @undergroundauth
              @undergroundauth - I don’t know whether the problem is already solved or not. Anyway, since noone mentioned it explicitly, here a note: you should copy/rename config.js.sample to config.js at first since changes to config.js.sample are completely ignored. Only the file config.js is used and so, your changes should only go there.
              • cowboysdudeC Offline
                cowboysdude Module Developer @Anhalter42
                This issue was solved.
