    MMM-voice
    8 Posts 2 Posters 4.1k Views 2 Watching
    • F Offline
      funkdafied
      Evening everyone,
      I just installed MMM-voice and everything appears to have installed correctly. However after starting MM the module shows ERROR next to microphone. Are there logs I can look for or how can I troubleshoot the issue?
      Thank you
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @funkdafied
        @funkdafied there is an error.log file in the modules directory. If it contains only numbers please add debug: true to your config. This will generate a detailed debug.log file.
        • F Offline
          funkdafied
          Here is the output from the debug.log:
          pocketsphinx_continuous: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such file or directory
          Here is the output from the error.log:
          127127127127127
          Since it appears that pocketsphinx is having an issue does any have any suggestions on how to correct the problem?
          Thank you
            @funkdafied a user reported this on github lately as well https://github.com/fewieden/MMM-voice/issues/8#issuecomment-296431212 can you check your bashrc file
            • F Offline
              funkdafied @strawberry 3.141
              @strawberry-3.141
              After a reinstall I’m still getting the error. Any additional suggestions?
                @funkdafied a user solved it on github 2 hours ago by himself, you might want to try if it works for you as well https://github.com/fewieden/MMM-voice/issues/8#issuecomment-297020666
                • F Offline
                  @strawberry-3.141
                  Thank you for the link. I’m not sure where I need to add the sudo command. I added it to the dependencies.sh
                  # exporting paths
                  echo -e "\e[96m[STEP 4/6] Exporting paths\e[0m"
                  echo "export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib" >> ~/.bashrc
                  echo "sudo ldconfig"
                  echo "export PKG_CONFIG_PATH=$PKG_CONFIG_PATH:/usr/local/lib/pkgconfig" >> ~/.bashrc
                  But I don’t believe that was the correct location. Please advise.
                  Thank you
                    @funkdafied he didnt modify the installer, he just put those commands into the terminal
