    MMM-awesome-alexa
    241 Posts 43 Posters 415.5k Views 47 Watching
    • G Offline
      Ghost2000
      This post is deleted!
      • G Offline
        Ghost2000 @sdetweil
        @sdetweil said in MMM-awesome-alexa:
        http://localhost:someportnumber >1000
        http://localhost:3000/ or http://localhost:3000/authresponse
        • G Offline
          Ghost2000 @sdetweil
          http://localhost:3000/authresponse = It does not work
          http://localhost:3000/ = It does not work
          Invalid. Please enter your Redirect URI.
            sdetweil @Ghost2000
            @Ghost2000 yes, looking at the code now…
            • G Offline
              Ghost2000
                sdetweil @Ghost2000
                @Ghost2000 yeh, some bug in their helper code… suddenly
                edit the config_helper.js
                change this line to return true;
                                return true; // "Invalid. Please enter your Redirect URI.";
                using your return url in my avs config and on the helper
                must copy ALL of the url from helper (2 lines) to the browser address field
                hit enter
                then sign in
                then click allow,
                apparently I have something running at port 3000
                but
                code is there
                  @Ghost2000 and it worked
                  • G Offline
                    Ghost2000 @sdetweil
                    @sdetweil NO
                    const chalk = require("chalk");
                    const clear = require("clear");
                    const figlet = require("figlet");
                    const inquirer = require("inquirer");
                    const request = require("request-promise");
                    const CLI = require("clui");
                    const spinner = new CLI.Spinner("Getting response from Amazon...");
                    const questions = [
                            type: "input",
                            message: "Enter your Client ID from Alexa Voice Service (AVS):",
                            validate: value => {
                                if (value.length) {
                                    return true;
                                } else {
                                    return "Please enter your Client ID.";
                            type: "input",
                            message: "Enter your Client Secret from Alexa Voice Service (AVS):",
                            validate: function(value) {
                                if (value.length) {
                                    return true;
                                } else {
                                    return "Please enter your Client Secret.";
                            type: "input",
                            message: "Enter your Product ID from Alexa Voice Service (AVS):",
                                if (value.length) {
                                    return true;
                                } else {
                                    return "Please enter your Product ID.";
                            type: "input",
                            message: "Enter your Redirect URI (allowed return URL) from Alexa Voice Service (AVS):",
                                const pattern = new RegExp(
                                    "^(https?:\\/\\/)?" + // protocol
                                    "((([a-z\\d]([a-z\\d-]*[a-z\\d])*)\\.)+[a-z]{2,}|" + // domain name
                                    "((\\d{1,3}\\.){3}\\d{1,3}))" + // OR ip (v4) address
                                    "(\\:\\d+)?(\\/[-a-z\\d%_.~+]*)*" + // port and path
                                    "(\\?[;&a-z\\d%_.~+=-]*)?" + // query string
                                        "(\\#[-a-z\\d_]*)?$",
                                    "i", // fragment locator
                                if (!!pattern.test(value)) {
                                    return true;
                                } else {
                                    return "Invalid. Please enter your Redirect URI.";
                    const authCodeQuestion = [
                            type: "input",
                            message: "Enter your Authorization code (from previous step):",
                                if (value.length) {
                                    return true;
                                } else {
                                    return "Please enter your Authorization Code.";
                    const continueQuestion = [
                            type: "confirm",
                            message: "Do you wish to continue to generate the MagicMirror config?",
                            default: true,
                    const configQuestions = [
                            type: "list",
                            message: "What do you want your Wake Word to be? (The phrase used to activate this module)",
                            choices: ["Alexa", "Smart Mirror", "Snowboy"],
                            type: "confirm",
                            message: "Do you want to use lite mode?",
                            default: false,
                            type: "confirm",
                            message: "Do you want to use visulization?",
                            default: true,
                    const generateQuery = params =>
                        Object.keys(params)
                            .map(key => key + "=" + params[key])
                            .join("&");
                    clear();
                    console.log(chalk.yellow(figlet.textSync("Awesome Alexa", { horizontalLayout: "full" })));
                    console.log(chalk.underline("Welcome to the Config Helper tool!"));
                    console.log("This tool will help you get the Refresh Token needed to run MMM-awesome-alexa.");
                    console.log(
                        "It will optionally generate your config for you, if you wish. If not, you can still create it manually after.",
                    console.log("Go to https://developer.amazon.com/alexa/console/avs/products to get the details.\n");
                    const run = async () => {
                        const output = await inquirer.prompt(questions);
                        const scopeData = {
                            "alexa:all": {
                                productID: output.productId,
                                productInstanceAttributes: {
                                    deviceSerialNumber: 123, // Can be anything
                        const queryParams = generateQuery({
                            client_id: output.clientId,
                            scope: "alexa:all",
                            scope_data: JSON.stringify(scopeData),
                            response_type: "code",
                            redirect_uri: output.redirectUri,
                        console.log(
                            chalk.blue("Hooray! Link is generated. Part 1 is done. Please go on the link below.\n"),
                        console.log(
                            chalk.yellow("Please be aware that at the end,"),
                            chalk.bgRed("THERE WILL BE AN ERROR!"),
                            chalk.green("This is normal.\n"),
                        console.log(`https://www.amazon.com/ap/oa?${queryParams}`);
                        console.log("\n^^^ Copy and paste the above in your Browser ^^^, follow the instructions.");
                        console.log(
                            "The authorization code you want is in the address bar in the final screen: https://imgur.com/a/6DbYlKA",
                        const authOutput = await inquirer.prompt(authCodeQuestion);
                        spinner.start();
                        const amazonTokenReponse = await request.post("https://api.amazon.com/auth/o2/token", {
                            form: {
                                grant_type: "authorization_code",
                                code: authOutput.authCode,
                                client_secret: output.clientSecret,
                            json: true,
                        spinner.stop();
                        console.log(
                            chalk.bgGreen(
                                "\nComplete! Your refresh token should be in the Amazon response below. If not raise an issue:\n",
                        console.dir(amazonTokenReponse, { colors: true });
                        const continueOutput = await inquirer.prompt(continueQuestion);
                        if (!continueOutput.continue) {
                            process.exit();
                        const configOutput = await inquirer.prompt(configQuestions);
                        console.log(chalk.green("\nCongrats! Here is the full config:\n"));
                        console.dir(
                                module: "MMM-awesome-alexa",
                                position: "bottom_bar",
                                    wakeWord: configOutput.wakeWord,
                                    clientId: output.clientId,
                                    clientSecret: output.clientSecret,
                                    deviceId: output.productId,
                                    refreshToken: amazonTokenReponse.refresh_token,
                                    lite: configOutput.liteMode,
                                    isSpeechVisualizationEnabled: configOutput.useVisualization,
                            { colors: true },
                    run();
                    Have You Teamview ? You can help :D
                      sdetweil @Ghost2000
                      @Ghost2000 said in MMM-awesome-alexa:
                                  return true;
                              } else {
                                  return "Invalid. Please enter your Redirect URI.";  < <<<<<<<<<< change that line
                      • G Offline
                        Ghost2000 @sdetweil
                        const questions = [
                                type: "input",
                                    if (value.length) {
                                        return true;
                                    } else {
                                type: "input",
                                    if (value.length) {
                                        return true;
                                    } else {
                                type: "input",
                                    if (value.length) {
                                        return true;
                                    } else {
                                type: "input",
                                        return true;
                                    } else {
                                        return true;
                                type: "input",
                                    if (value.length) {
                                        return true;
                                    } else {
                                type: "confirm",
                                default: true,
                                type: "list",
                                type: "confirm",
                                default: false,
                                type: "confirm",
                                default: true,
                            Object.keys(params)
                                .join("&");
                        clear();
                        console.log(
                            const scopeData = {
                                "alexa:all": {
                                scope: "alexa:all",
                            console.log(
                            console.log(
                            console.log(
                            spinner.start();
                                form: {
                                json: true,
                            spinner.stop();
                            console.log(
                                chalk.bgGreen(
                                process.exit();
                            console.dir(
                                { colors: true },
                        run();
                          sdetweil @Ghost2000
                          @Ghost2000 yes, now execute the
                          node config-helper.js
                          again
                            sdetweil
                            Sie haben einen Fehler bei der Suche nach einer gültigen URL-Zeichenfolge. Wir werden den Test überspringen
                            • G Offline
                              Ghost2000
                              pi@MagicMirror:~/MagicMirror/modules/MMM-awesome-alexa $ node config_helper.js
                              internal/modules/cjs/loader.js:638
                                  throw err;
                              Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/config_helper.js'
                                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                  at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                  at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                                  at startup (internal/bootstrap/node.js:283:19)
                                  at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                sdetweil @Ghost2000
                                @Ghost2000 sorry, config-helper.js
                                dash not underscore
                                you executed the command many times before, you should have known to fix my typo
                                • G Offline
                                  Ghost2000
                                  http: // localhost: 3000 / oder http: // localhost: 3000 / authresponse
                                  which one is correct?
                                    sdetweil @Ghost2000
                                    • G Offline
                                      Ghost2000
                                      • G Offline
                                        Ghost2000
                                          sdetweil
                                          • G Offline
                                            Ghost2000
                                            it works with your settings.
                                            http: // localhost: 3000 /? code = ANMcPyM …
                                            DANKE DANKE DANKE DANKE DANKE ! LOVE YOU!
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
