MMM-cryptocurrency - v1.4
@fox Well, css is the right place.
You should get the class and fix in css file. Let me know if you need help. -
@matteodanelli
Thank you. But i dont find the distance. Only the font size for some entries -
@fox Yes, because padding is set at default value. You should set it explicitly where needed.
@matteodanelli
Would it be possible that you could give me an example? I dont know how to work with padding.
Thank you in advance -
Hello,
where can i find the sparkline id’s ?
is it possible to add the NLG.https://coinmarketcap.com/currencies/gulden/
thanks
@Honsbeek go to coinmarketcap, in the list where you see all of the coins, right click on the graph of the desired coin, “open image in new tab” (in chrome), read the number from the url
for gulden is 254 -
hello! can someone explain me how can i add a coin that is not in the list of coins? (by the way great module!!)
@marinswk well i managed alone at the end…you just need to increase the limit
@marinswk said in MMM-cryptocurrency - v1.4:
Yes! And the symbol you take from Coinmarketcap, thats all for now
@fox Yes, and from the GH issue I filed, he added the first 100 coins, its easily scriptable to add all.
Could someone add Vertcoin?
@bocapie File an issue and ask the repo owner, he’s really friendly and helpful.
Is there a way to display your coin amount?
@bocapie said in MMM-cryptocurrency - v1.4:
Coinmarketcap changed the URLs to their sparkline graphs some time yesterday. Old URLs still load but don’t update anymore. I created a pull request with the updated URL.
Hi, I am trying to add a newish token to this, but can’t seem to get it to work. I have added the token name and ID to MMM-cryptocurrency.js in the sparklineIDs section, and then added it to my config.js using the name, but it still doesn’t show up.
Am I missing something out?
MMM-cryptocurrency.js - I added ‘summit-koda-token’: 9966,
config.js - I added ‘summit-koda-token’ to the currency section.My eth, bitcoin still show fine.
@causerino Hi!
I know it’s been a while, but I’ve done this as well.
Make sure the SparklineIDs name corresponds with the slug name provided by CoinMarketCaps API.For example, I wanted to add Elrond’s eGLD.
The ID for this token is 6892, while the slug is elrond-egld. As this includes a hyphen symbol, it needs to be surrounded by quote marks.
So my addition looks like this:'elrond-egld': 6892,I also made 2 symbols, which are not required but look pretty.
