    MMM-Vrr - Transport Information for VRR, North Rhine-Westphalia Germany
    transportationgermanyvrr
    15 Posts 5 Posters 11.5k Views 5 Watching
    • KlizzyK Offline
      Klizzy Module Developer
      Description:
      I wrote an MagicMirror Module for most Citys in North Rhine-Westphalia, Germany.
      It supports all Transportation within VRR and has limited support for areas outside of it.
      its my first Project on Github, so im open to suggestions and / or tipps on improving the Module ☺️
      Screenshots:
      MMM-VRR
      MMM-VRR
      Download:
      [card:Klizzy/MMM-Vrr]
      Changelog
      Version 1.0
      • initial release
      Version 1.1
      • added some additional configuration to set a custom width
      • added the option to scroll the destination text horizontally
      Version 1.2
      • now displays delays
      Version 1.5
      • delay bugfix and styling changes
      • rail track is now displayed
      • added additional display type
      Version 1.5.1
      • fix for Issue #3 scrollAfter and displayType lcd
      Version 1.6
      • shown lines can now be filtered and code improvements. THX @wapolinar !
      • added contributing.md
      Social
      Twitter
      Github
      Working on the following Modules:
      • MMM-Vrr
      • MMM-cryptocurrency
      Sandy2503S 1 Reply Last reply Reply Quote 1
      • Sandy2503S Offline
        Sandy2503 @Klizzy
        @Klizzy - this modul is a intresting alternative to the module MMM-EFA-Departures …
        Is it possible to integrate Delaytimes ??
        Greetz Sandy2503
        KlizzyK 1 Reply Last reply Reply Quote 0
        • KlizzyK Offline
          Klizzy Module Developer @Sandy2503
          @Sandy2503
          thanks!
          Yes i’ll integrate it in a couple of days ☺️
          Social
          Twitter
          Github
          • MMM-Vrr
          • G Offline
            gismo2006
            Hi, till now I have use a module by myself to display Picture from finalrewind. But now I use your modul. Its perfect! Thank you! But a little question I have, too. :-) Is it possible to programmed fixed size of your module? I like to explain what I mean, I five buses displayed. But the destination of the buses not the same. So if there five buses whit short destinations like abc, its ok but then there are five buses whit long destinations like abcdefghijklm, your modul will adjust size.
            greets gismo
            KlizzyK 1 Reply Last reply Reply Quote 1
            • KlizzyK Offline
              Klizzy Module Developer @gismo2006
              @gismo2006
              thank you! Its nice to hear that some people are using it! ☺️
              I added some additional configuration settings, so you can specify an fixed width bei yourself in pixel (e.g 350px).
              But the text would get an additional line break if the string is to long, so i added a vertical scrolling feature.
              Just look at the instructions at github.
              @Sandy2503
              i think that i will be ready with your request in a couple of hours
              Social
              Twitter
              Github
              • MMM-Vrr
              Sandy2503S 1 Reply Last reply Reply Quote 0
              • G Offline
                gismo2006
                @Klizzy
                Hello, Sorry I didn´t see it till now. Maybe I need a glass. But now I have tested the option setWidth and scrollAfter but nothing happend. There was no error but it didn´t work, too. I have set your option at my config file at the config block of your module. There I have set the numberofResults to 5. This works perfect. Do you have any Ideas?
                greets gismo
                • KlizzyK Offline
                  @gismo2006
                  did you updated the source files?
                  you have to delete the old Version of the MMM-Vrr module and download the new one.
                  So just replace the source files with the updated one and you configs should work after an restart
                  Social
                  Twitter
                  Github
                  • MMM-Vrr
                    Sandy2503 @Klizzy
                    @Klizzy
                    Maybe You could add the delay time like in the MMM-RNV Module
                    Sandy
                    • KlizzyK Offline
                      @Sandy2503
                      the module now displays delays.
                      Just update the source code and thank you for your suggestion!
                      Social
                      Twitter
                      Github
                      • MMM-Vrr
                      • G Offline
                        gismo2006
                        @Klizzy
                        Hey, a wonderfull morning :-)
                        I only like to say now everthing works fine!!
                        I shouldn ´t sit in front of my mm so early… :-D I haven´t seen your sentences: “I added…” and don´t update my source.
                        Thank you!
                        Today I will write you a PN, if it is Ok for you, maybe you can help me too.
                        greets gismo
                          Sandy2503 @Klizzy
                          @Klizzy
                          Wow - now it looks really COOOOOL ! ! !
                          Thank You
                          Sandy2503
                          • KlizzyK Offline
                            @gismo2006
                            sure ☺️
                            @Sandy2503
                            nice setup and thanks for the picture!
                            Social
                            Twitter
                            Github
                            • MMM-Vrr
                            • P Offline
                              paat
                              Hello nice module! Thanks for the effort!
                              Am I right that the module does not work with VRS cities like Cologne for example?
                              • U Offline
                                ueffchen
                                Hi
                                the module is great!
                                How can I change the fontsize?
                                I was trying to change it in the custom.css, but I don’t understand which fontname I have to enter.
                                Thanks!
                                • KlizzyK Offline
                                  Klizzy Module Developer @ueffchen
                                  Hello @ueffchen ,
                                  sorry for the late reply!
                                  If you still got this problem, you can fix it in multiple ways:
                                  MMM Build in sizing
                                  You could change tableWrapper.className = "small mmm-vrr-table"; within MMM-Vrr.js on line 159 into tableWrapper.className = "medium mmm-vrr-table";
                                  Specific font sizes for header
                                  add another line after MMM-Vrr.css:16 with you desired fontsize e.g: font-size: 50px;
                                  Specific font size within table content
                                  add this to the MMM-Vrr.css
                                  .mmm-vrr-table tr {
                                      font-size: 50px;
                                  Social
                                  Twitter
                                  Github
                                  • MMM-Vrr
