    MMM-RNV
    9 Posts 2 Posters 5.8k Views 2 Watching
    • Y Offline
      yawns Moderator
      Description:
      It monitors a given station in the RNV traffic network and shows the 10 upcoming departures with destination, type and delay. It also shows additional information if provided by the vendor.
      Screenshots:
      Download:
      [card:yawnsde/MMM-RNV]
      Version 1.0.0
      • initial release
      Version 1.1.0
      • some more error handling
      • added some tweaks in case the start time is after midnight, then the parsing failed
      • added the alert ticker if some alert is present
      • updated the readme
      • removed odd default value for stationID from the module
      • Y Offline
        yawns Moderator
        I just updated the module, after I noticed the layout is slightly broken when added to an area on the right side of the screen.
          mcg
          Hey @yawns, looks great!
          Even the differentiation between tram and bus, cool!
          I was surprised by the delay times as well, when I thought about building such a module (and thus starting to learn JS) I just had a rough look at the VRN API which doesn’t offer any real time data.
          I have two feature requests:
          • configurable number of shown connections
          • configurable direction (or destination)
          Cheers!
          Y 1 Reply Last reply Reply Quote 1
          • Y Offline
            yawns Moderator @mcg
            @mcg
            Hi, glad you like it.
            What do you mean with configurable direction?
              mcg
              I mean that I dont want to see all connections leaving from that particular stop but just in one direction.
              E.g. if I lived near a final destination I would just want to see the city-bound connections.
                mcg
                Hey @yawns!
                I finally had a deeper look into the API and your code and felt free to adapt it a little according to my needs.
                I did the following things:
                • added the so called poles to be defined in the personal config
                  this enables one to choose certain tracks/platforms at a particular stop (this was what i spoke about when I replied to your post the first time)
                • added a time offset, which it would take one to reach the acutal stop (by foot).
                • correction of the current time format from 12h to 24h, which led to an error when I tested the offset. (from hh --> HH)
                • edited the readme
                Because I’m completely new to Github I hope I did the most of it right till now. Guess the next step would be to create a pull request if you like, right?
                Cheers!
                • Y Offline
                  yawns Moderator
                  Looks good, I like your changes. Yes please, submit a pull request and I will add it to the main repository so other users can benefit from your changes
                    mcg
                    Alright,
                    i found a bug which led to still showing connections after the offset.
                    Newest release has
                    • offset bug fixed
                    • new option to choose how many departures shall be shown (between 1 and 10)
                    I’m gonna test this release a few days and then send a pull request :)
                      mcg
                      Alright, I sent you a pull request.
                      Additionally, I’m currently testing another new feature where
                      • delay is shown for all connections which have already started even if there is no delay.
