MMM-Vrr - Transport Information for VRR, North Rhine-Westphalia Germany
transportationgermanyvrr
15 Posts 5 Posters 8.8k Views 5 Watching
  • K Offline
    Klizzy Module Developer
    Description:
    I wrote an MagicMirror Module for most Citys in North Rhine-Westphalia, Germany.
    It supports all Transportation within VRR and has limited support for areas outside of it.
    its my first Project on Github, so im open to suggestions and / or tipps on improving the Module ☺️
    Screenshots:
    MMM-VRR
    MMM-VRR
    Download:
    [card:Klizzy/MMM-Vrr]
    Changelog
    Version 1.0
    • initial release
    Version 1.1
    • added some additional configuration to set a custom width
    • added the option to scroll the destination text horizontally
    Version 1.2
    • now displays delays
    Version 1.5
    • delay bugfix and styling changes
    • rail track is now displayed
    • added additional display type
    Version 1.5.1
    • fix for Issue #3 scrollAfter and displayType lcd
    Version 1.6
    • shown lines can now be filtered and code improvements. THX @wapolinar !
    • added contributing.md
    Social
    Twitter
    Github
    Working on the following Modules:
    • MMM-Vrr
    • MMM-cryptocurrency
    S 1 Reply Last reply May 21, 2017, 4:38 PM Reply Quote 1
      Sandy2503 @Klizzy
      @Klizzy - this modul is a intresting alternative to the module MMM-EFA-Departures …
      Is it possible to integrate Delaytimes ??
      Greetz Sandy2503
      K 1 Reply Last reply May 21, 2017, 4:45 PM Reply Quote 0
      • K Offline
        Klizzy Module Developer @Sandy2503
        @Sandy2503
        thanks!
        Yes i’ll integrate it in a couple of days ☺️
        Social
        Twitter
        Github
        • MMM-Vrr
        • G Offline
          gismo2006
          Hi, till now I have use a module by myself to display Picture from finalrewind. But now I use your modul. Its perfect! Thank you! But a little question I have, too. :-) Is it possible to programmed fixed size of your module? I like to explain what I mean, I five buses displayed. But the destination of the buses not the same. So if there five buses whit short destinations like abc, its ok but then there are five buses whit long destinations like abcdefghijklm, your modul will adjust size.
          greets gismo
          K 1 Reply Last reply Jun 4, 2017, 3:01 AM Reply Quote 1
          • K Offline
            Klizzy Module Developer @gismo2006
            @gismo2006
            thank you! Its nice to hear that some people are using it! ☺️
            I added some additional configuration settings, so you can specify an fixed width bei yourself in pixel (e.g 350px).
            But the text would get an additional line break if the string is to long, so i added a vertical scrolling feature.
            Just look at the instructions at github.
            @Sandy2503
            i think that i will be ready with your request in a couple of hours
            Social
            Twitter
            Github
            • MMM-Vrr
            S 1 Reply Last reply Jun 4, 2017, 1:42 PM Reply Quote 0
            • G Offline
              gismo2006
              @Klizzy
              Hello, Sorry I didn´t see it till now. Maybe I need a glass. But now I have tested the option setWidth and scrollAfter but nothing happend. There was no error but it didn´t work, too. I have set your option at my config file at the config block of your module. There I have set the numberofResults to 5. This works perfect. Do you have any Ideas?
              greets gismo
              K 1 Reply Last reply Jun 4, 2017, 12:58 PM Reply Quote 0
              • K Offline
                @gismo2006
                did you updated the source files?
                you have to delete the old Version of the MMM-Vrr module and download the new one.
                So just replace the source files with the updated one and you configs should work after an restart
                Social
                Twitter
                Github
                • MMM-Vrr
                  Sandy2503 @Klizzy
                  @Klizzy
                  Maybe You could add the delay time like in the MMM-RNV Module
                  Sandy
                  K 1 Reply Last reply Jun 4, 2017, 10:54 PM Reply Quote 0
                  • K Offline
                    @Sandy2503
                    the module now displays delays.
                    Just update the source code and thank you for your suggestion!
                    Social
                    Twitter
                    Github
                    • MMM-Vrr
                    S 1 Reply Last reply Jun 5, 2017, 12:10 PM Reply Quote 0
                    • G Offline
                      gismo2006
                      @Klizzy
                      Hey, a wonderfull morning :-)
                      I only like to say now everthing works fine!!
                      I shouldn ´t sit in front of my mm so early… :-D I haven´t seen your sentences: “I added…” and don´t update my source.
                      Thank you!
                      Today I will write you a PN, if it is Ok for you, maybe you can help me too.
                      greets gismo
                      K 1 Reply Last reply Jun 5, 2017, 2:01 PM Reply Quote 0
