    MMM-MyCommute
    286 Posts 80 Posters 684.5k Views 77 Watching
      matt216 @lavolp3
      @lavolp3 thanks - the node_helper and multiple browsers makes sense now.
      No - no MMM-pages or module schedulers being used.
      I have my startTime option set to 05:00. I will try a cron job to pm2 restart mm at 05:15…
      • lavolp3L Offline
        lavolp3 Module Developer @matt216
        @matt216 there might be an issue with your start and end time. Can you post your config for the module?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          matt216 @lavolp3
          @lavolp3
                          module: 'MMM-MyCommute',
                          position: 'bottom_left',
                          header: 'Google Maps',
                                  apiKey: 'xyz',
                                  origin: 'xyz',
                                  startTime: '05:00',
                                  endTime: '20:00',
                                  showUpdated: false,
                                  destinations:
                                          destination: 'xyz',
                                          label: 'Erica commute',
                                          mode: 'driving'
          • lavolp3L Offline
            @matt216 no errors here.
            You could also try @qistophs fork
            https://github.com/qistoph/MMM-MyCommute
            If you’e not doing already.
            The original module has been abandoned.
              matt216 @lavolp3
              @lavolp3 already using @qistoph fork, yes. I can see on github there are issues raised around this. Also another fork by @radokristof which I’ll try.
                matt216
                Initial test with @radokristof fork looks good. Doesn’t come up immedately at startTime, but soon after. Guess that has to do with the poll interval.
                • 11
                • 12
                • 13
                • 14
                • 15
                • 15 / 15
