    Installing MM2
    20 Posts 6 Posters 20.1k Views 5 Watching
    • N Offline
      Neokamikaze
      Same error for me (Raspberry Pi 3 / Jessie)
      • BangeeB Offline
        Bangee Module Developer
        as I c, you’ve installed your MagicMirror in the /root directory.
        I’m not sure if this is working so far.
        Try to install everything as pi and not as root in the /home/pi directory and let us know what happend.
        try whoami -> pi
        update your distribution with sudo apt-get update && sudo apt-get upgrade
        then cd /home/pi or only cd
        and install again: curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
        G B B 3 Replies Last reply Reply Quote 0
        • G Offline
          gzot @Bangee
          @Bangee
          I just try to launch the autoinstaller as pi in /home/pi and it works !
          Thanks a lot ;)
          • N Offline
            Neokamikaze
            Yes, when i installing with the user pi, it’s work. But now i Have this message
            npm ERR! Linux 4.4.13-v7+
            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
            npm ERR! node v6.2.1
            npm ERR! npm  v3.9.3
            npm ERR! code ELIFECYCLE
            npm ERR! electron-prebuilt@1.2.5 postinstall: `node install.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the electron-prebuilt@1.2.5 postinstall script 'node install.js'.
            npm ERR! If you do, this is most likely a problem with the electron-prebuilt package,
            npm ERR! not with npm itself.
            npm ERR!     node install.js
            npm ERR!     npm bugs electron-prebuilt
            npm ERR! Or if that isn't available, you can get their info via:
            npm ERR!     npm owner ls electron-prebuilt
            • BangeeB Offline
              ok, and whats inside of this file: /home/pi/MagicMirror/npm-debug.log
              Can you share this with us?
                berry @Bangee
                @Bangee said in Installing MM2:
                try whoami -> pi
                worked for me !! thanks
                at least i shouldnt tried to install MM2 as root
                • N Offline
                  Neokamikaze
                  Hi Bangee,
                  Sorry for this late. Find this my npm file.
                  0_1467112984554_npm-debug.log
                  • N Offline
                    Neokamikaze
                    I restart all installation and now my depencies is OK. But when i start “npm start” i have one erreur. This debug file:
                    1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
                    2 info using npm@3.9.5
                    3 info using node@v6.2.2
                    5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
                    6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
                    7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
                    8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
                    9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/$
                    10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
                    11 silly lifecycle magicmirror@2.0.0~start: Args: [ '-c', 'electron js/electron.js' ]
                    12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1  signal: null
                    13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
                    14 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
                    14 verbose stack Exit status 1
                    14 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:245:16)
                    14 verbose stack     at emitTwo (events.js:106:13)
                    14 verbose stack     at EventEmitter.emit (events.js:191:7)
                    14 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:24:14)
                    14 verbose stack     at ChildProcess.emit (events.js:191:7)
                    14 verbose stack     at maybeClose (internal/child_process.js:852:16)
                    14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
                    15 verbose pkgid magicmirror@2.0.0
                    16 verbose cwd /home/pi/MagicMirror
                    17 error Linux 4.4.14-v7+
                    18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                    19 error node v6.2.2
                    20 error npm  v3.9.5
                    21 error code ELIFECYCLE
                    22 error magicmirror@2.0.0 start: `electron js/electron.js`
                    22 error Exit status 1
                    23 error Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                    23 error Make sure you have the latest version of node.js and npm installed.
                    23 error If you do, this is most likely a problem with the magicmirror package,
                    23 error not with npm itself.
                    23 error Tell the author that this fails on your system:
                    23 error     electron js/electron.js
                    23 error You can get information on how to open an issue for this project with:
                    23 error     npm bugs magicmirror
                    23 error Or if that isn't available, you can get their info via:
                    23 error     npm owner ls magicmirror
                    23 error There is likely additional logging output above.
                    24 verbose exit [ 1, true ]
                    • N Offline
                      Neokamikaze
                      I found my problem. I need start “npm start” directly on my session “pi”.
                      Thanks all
                        Bu52 @Bangee
                        @Bangee
                        first, I’m rather new to the RPi.
                        Second, I’m having issues installing MM2.
                        1. started with a 32G sd and installed Raspian.
                        2. then did sudo apt-get update, followed by sudo apt-get upgrade.
                        3. cd /home/pi.
                        4. Then curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                        5. All went well, except the last lines, which were:
                          Cloning MagicMirror Done!
                          Installing dependencies …
                          bash: line 108: npm: command not found
                        6. the cd ~/MagicMirror followed by npm start
                          I get the following error message, “bash: npm: command not found”.
                          What am I doing wrong, please.
