    Michelleoj's Mirror
    8 Posts 3 Posters 8.8k Views 3 Watching
    • M
      michelleoj
      I guess I’ll be the first to post in this section :smile:
      Here’s my mirror!
      alt text
      I used an acrylic 2 way mirror and for the monitor I used an 22" LED ViewSonic
      • P
        paviro
        Nice! Are you running v1 or v2?
        – The Doctor
        • M
          michelleoj
          V2. Made it so easy to make a module that pulls quotes from a tumblr blog using the tumblr api.
          • P
            paviro
            Would you like to share your module?
            – The Doctor
            • M
              michelleoj
              Yeah sure! It’s super hacky though since it was done for a hackathon
              https://github.com/michelleoj/MagicMirror/tree/mm-tumblr
              • P
                paviro
                Could you add it to a separate repository so it is easier for others to install? Have a look here for some examples, would be great if you would add it to the showcase after that!
                Also note you do not have to add a module to the default folder for it to be loaded!
                – The Doctor
                • M
                  michelleoj
                  Oh thanks for the tip! I’ll clean it up some and then add it to showcase.
                  • I
                    idkmynameiskyle
                    Looks awesome Michelleoj!
