    MMM-Temperature-Humidity NODE_VERSION Error
    9 Posts 3 Posters 4.1k Views 3 Watching
    • C
      caner
      Hello,
      I installed MMM-Temperature-Humidity, installed all directions, and run magic mirror but had an error in terminal like this:
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-Temperature-Humidity/node_modules/rpi-dht-sensor/build/Release/node_dht_sensor.node’
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 51. This version of Node.js requires
      NODE_MODULE_VERSION 53. Please try re-compiling or re-installing
      the module (for instance, using npm rebuild ornpm install).
      node version: 7.10.0
      npm version 4.2.0 (tried in 4.5.0 too)
      How can i solve it? :/
      • cowboysdudeC
        cowboysdude Module Developer
        go to MagicMirror/modules/MMM-Temperature-Humidity dir in a terminal window and type…
        npm install
        • C
          caner
          Already did it. Doesnt work.
          • cowboysdudeC
            cowboysdude Module Developer @caner
            @caner Did you get any errors during npm install?
            • C
              caner
              @cowboysdude nope. Installed again. Its like this:
              pi@ozdemir:~ $ cd ~/MagicMirror/modules/
              pi@ozdemir:~/MagicMirror/modules $ git clone https://github.com/prasanthsasikumar/MMM-Temperature-Humidity.git
              Cloning into 'MMM-Temperature-Humidity'...
              remote: Counting objects: 11, done.
              remote: Total 11 (delta 0), reused 0 (delta 0), pack-reused 11
              Unpacking objects: 100% (11/11), done.
              Checking connectivity... done.
              pi@ozdemir:~/MagicMirror/modules $ cd ~/MagicMirror/modules/MMM-Temperature-Humidity/
              pi@ozdemir:~/MagicMirror/modules/MMM-Temperature-Humidity $ npm install
              > rpi-dht-sensor@0.1.1 install /home/pi/MagicMirror/modules/MMM-Temperature-Humidity/node_modules/rpi-dht-sensor
              > node-gyp rebuild
              make: Entering directory '/home/pi/MagicMirror/modules/MMM-Temperature-Humidity/node_modules/rpi-dht-sensor/build'
                CC(target) Release/obj.target/node_dht_sensor/src/bcm2835.o
                CXX(target) Release/obj.target/node_dht_sensor/src/node-dht-sensor.o
                SOLINK_MODULE(target) Release/obj.target/node_dht_sensor.node
                COPY Release/node_dht_sensor.node
              make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Temperature-Humidity/node_modules/rpi-dht-sensor/build'
              mmm-temperature-humidity@0.1.0 /home/pi/MagicMirror/modules/MMM-Temperature-Humidity
              └─┬ rpi-dht-sensor@0.1.1
                ├── bindings@1.2.1
                └── nan@2.6.2
              • C
                caner
                @cowboysdude but i had an error like this when install rpi-dht-sensor
                pi@ozdemir:~ $ sudo apt-get install rpi-dht-sensor
                Reading package lists... Done
                Building dependency tree
                Reading state information... Done
                E: Unable to locate package rpi-dht-sensor
                pi@ozdemir:~ $
                • cowboysdudeC
                  @caner Yes I also got an error trying to install that package… not sure why yet.
                  • U
                    uzumon
                    First you should install rpi-dht-sensor by node:
                    npm install rpi-dht-sensor
                    I have the same problem but on module:
                    https://github.com/bernardpletikosa/MMM-DHT-Sensor
                    2017-06-09 10:30 +02:00: Error: The module ‘/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rpi-dht-sensor/build/Release/node_dht_sensor.node’
                    NODE_MODULE_VERSION 48. This version of Node.js requires
                    at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                    at Object.Module._extensions…node (module.js:598:18)
                    at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                    at Module.load (module.js:488:32)
                    at tryModuleLoad (module.js:447:12)
                    at Function.Module._load (module.js:439:3)
                    at Module.require (module.js:498:17)
                    at require (internal/module.js:20:19)
                    at bindings (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/bindings/bindings.js:76:44)
                    at Object. (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rpi-dht-sensor/main.js:3:34)
                    I did npm install and rebuild and the same.
                    Someone can help?
                    • U
                      uzumon
                      Ok for module_version you have to run
                      npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49
                      where 1.3.4 is you current version of electron and 49 is version which is required.
                      After this i have another problem:
                      **2017-06-12 11:58 +02:00: bcm2835_init: Unable to open /dev/mem: Access denied**
                      0|mm       | 2017-06-12 11:58 +02:00: TypeError: Failed to initialize
                      0|mm       |     at DHT.read (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rpi-dht-sensor/main.js:7:18)
                      0|mm       |     at Class.checkTemperature (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:36:32)
                      0|mm       |     at Timeout._onTimeout (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:29:18)
                      0|mm       |     at ontimeout (timers.js:365:14)
                      0|mm       |     at tryOnTimeout (timers.js:237:5)
                      0|mm       |     at Timer.listOnTimeout (timers.js:207:5)
                      When i run sudo npm start in MagicMirror folder i get errors.;/
                      npm ERR! Linux 4.9.24-v7+
                      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                      npm ERR! node v6.11.0
                      npm ERR! npm  v3.10.10
                      npm ERR! code ELIFECYCLE
                      npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
                      npm ERR! If you do, this is most likely a problem with the magicmirror package,
                      npm ERR! not with npm itself.
                      npm ERR!     sh run-start.sh
                      npm ERR!     npm bugs magicmirror
                      npm ERR! Or if that isn't available, you can get their info via:
                      npm ERR!     npm owner ls magicmirror
                      Sameone can help now?
