    MMM-MyTTC (Toronto Transit)
    27 Posts 9 Posters 15.7k Views 9 Watching
    • T Offline
      TheGeekfather @Mykle1
      @Mykle1
      MyTTC stops at loading - does it require an API? - followed all steps for the ttc.
      Another GREAT MODULE !!!
        sdetweil
        @TheGeekfather said in MMM-MyTTC (Toronto Transit):
        MyTTC
        I installed the module and setup using the default config in the readme
        it failed with this message
        [22:04:25.291] [LOG]    raw ={"copyright":"All data copyright Toronto Transit Commission 2019.","Error":{"content":"For agency=ttc stop s=1148 is on none of the directions for r=143 so cannot determine which stop to provide data for.","shouldRetry":"false"}}
        i removed stop 1148 from the stop request and it all works…
        add this line to the node_helper.js and then look at the output on the terminal window or in the pm2 logs
            var predictionsArray = new Array();
        		console.log("raw ="+JSON.stringify(rawJSON));   // add this line < - --
            if (rawJSON.predictions.length) {
        the module is unable to tell u about error conditions like this
        • T Offline
          TheGeekfather @sdetweil
          AWESOME !!!
          You are correct - removed the stop 1148 and it WORKS !! :)
          Thank you - worked on this for hours!!
          • L Offline
            Lvl15_Gazebo
            Hello! I’m a newb to this community so I hope it’s ok if I resurrect this old thread. I just started trying to set up my Magic Mirror and got caught on the MyTTC Module not working properly. I managed to fix it and wanted to relay this to others so they could too. I’m not sure how to fork a module and upload it otherwise so hopefully someone whose been coding longer might be able to do it!
            Anyway, Nextbus changed the URL for making XML requests so I had to change this line in the node_helper.js:
            webServiceURL: “https://retro.umoiq.com/service/publicJSONFeed”,
            To this line:
            webServiceURL: “http://webservices.nextbus.com/service/publicJSONFeed”,
            I’m also having some issues with getting the Line and Stop numbers from the TTC as what I put in doesn’t seem to line up with what Nextbus/Umoiq has, but I’m still working on that. I hope this helps someone who is running into the same issues.
              sdetweil @Lvl15_Gazebo
              @Lvl15_Gazebo great work.
              to fork on the module GitHub page push the fork button, top right.
              now u have YOUR own copy
              git clone that to magic mirror
              (rename the old one first)
              now u can copy in the files u changed from the old one to your copy
              git status
              will show the changed files
              when u want to update your copy on GitHub
              git add xxx
              each of the files u changed (that’s xxx)
              and then git commit -m" some message about why these changes"
              then git push to upload the repo to github
              if u want to contribute those back to the source module, you will see a contribute button to make a pull request
              • L Offline
                Lvl15_Gazebo @sdetweil
                @sdetweil Thanks! I’ll give that a shot.
                I also determined last night that there is now a third variable for the transit request on UMOIQ for “direction” so I’ll try to figure that out before I submit anything. I’m not the best coder so that might take a bit, haha. Hopefully, I don’t need to change the XML parsing too!
                  @Lvl15_Gazebo cool. if u get stuck ask away
