    Can't config on Pi Zero
    4 Posts 2 Posters 1.9k Views 2 Watching
    • W
      Willou
      Hi all,
      I try to use MM2 on my Pi Zero W.
      All is installed (node, npm, git, php5, midori, unclutter, …).
      MM2 is cloned in /var/www/html (why this folder ?)
      autostart is configured.
      So I reboot my Pi Zero.
      serveronly, fullscreen, no cursor. Well, that say “please create a config file” as expected.
      I duplicate config.js.sample to config.js in /config folder. I reboot. then … same thing, “please create a config file”.
      I tried /MagicMirror folder, /js, /serveronly. Nothing better.
      What did I miss ? :disappointed_relieved:
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Willou
        @Willou
        It would seem that your config.js.sample file is corrupted or changed if you are simply copying and renaming it. It SHOULD work. Is it in your MagicMirror/config/ directory?
        I would download a new/fresh config.js.sample file and try again, just to make sure. It certainly will eliminate the possibility that it’s your config.js file, and it can’t hurt. This is where it should be
        pi@Pi3:~/MagicMirror/config/config.js
        Otherwise, you can copy and paste this, which is my config.js.sample file. Save it as config.js in the pi@Pi3:~/MagicMirror/config/ directory
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "US Holidays",
        						symbol: "calendar-check-o ",
        						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
        			module: "compliments",
        			position: "lower_third"
        			module: "currentweather",
        				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
        				appid: "YOUR_OPENWEATHER_API_KEY"
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        				showSourceTitle: true,
        				showPublishDate: true
        • W
          Willou
          I did a fresh copy, also changed config.js by your file’s data. Nothing more.
          I’ll try with chromium or kweb.
          • Mykle1M
            @Willou
            I don’t think it’s the browser. MM is running and telling you that something is wrong with the config.js file. If nothing is wrong with the config.js file then I suspect it’s a path issue. MM only looks in the MagicMirror/config/ directory for the config.js file. I can’t think of anything else at the moment.
