    Roomtemperature with DS18B20
    11 Posts 4 Posters 6.9k Views 3 Watching
    • C Offline
      Chiggo
      Hello everybody,
      I am new to this forum and I am trying to display the roomtemperature with a DS18B20 sensor at my MagicMirrorv2.
      I have installed ‘ds18x20’ to get the temperature using node.js, butit seems to be impossible for me, to display this at my MagicMirror.
      I can read the temp using this commands, and it shows the temp at the console.
      var sensor = require('ds18x20');
      var temp = sensor.get('28-00000574c791');
      console.log(temp);
      I tried to write a module from exsting code to display the temp at the mirror, but everything it shows is this picture
      Here is the code
      /* global Module */
      /* Magic Mirror
       * Module: MMM-Temperature
      Module.register('MMM-Temperature', {
      // Define start sequence.
              start: function() {
                      Log.info("Starting module: " + this.name);
                      // Schedule update interval.
                      var self = this;
                      setInterval(function() {
                              self.updateDom();
                      }, 1000);
      // Get temperature.
      tempRead: function() {
              var sensor = require ('ds18x20');
              var temp = sensor.get('28-04163746c8ff');
              return temp;
      // Override dom generator.
              getDom: function() {
      var temperature = this.tempRead();
      var celsius = document.createTextNode(temperature);
      wrapper.appendChild(celsius);
      return wrapper;
      Can someone explain to me, how to get this thing working!?
      • MichMichM Offline
        MichMich Admin
        What is important to understand, is the difference between the frontend module, and the node_helper.
        The frontend module (yourmodulename.js) is there to make sure the UI works, the node helper (node_helper.js) allows you to execute commands like you want.
        You need to make a module that contains both.
        Check out this very simple example which is pretty easy for you to adapt:
        https://github.com/MichMich/mmm-systemtemperature
        • MichMichM Offline
          MichMich Admin
          To point you a bit more in the right direction, the node helper should change to something like:
          sendTemperature: function() {
          	this.sendSocketNotification('TEMPERATURE', temp);
          • C Offline
            Chiggo
            Thank you for fast reply.
            I will give it a try tomorrow and check if i get it.
            My first steps in JS :sweat_smile:
            • C Offline
              Chiggo
              Spend some time to figure out what you mean, but i stuck again.
              Now at this point picture
              Here is the MMM-Temperature.js
                      defaults: {
                              prependString: 'Raumtemperatur: '
                      start: function() {
                              this.temperature = 'fetching...';
                              this.sendSocketNotification('CONNECT');
                      socketNotificationReceived: function(notification, temp) {
                          if (notification === 'TEMPERATURE') {
                              this.temperature = temp;
                              this.updateDom();
                              wrapper.innerHTML = this.config.prependString + this.temperature;
                              return wrapper;
              And here is the node_helper.js
              var NodeHelper = require("node_helper");
                      start: function function_name () {
                              var self = this;
                                      self.sendTemperature();
                              }, 10000);
                              var self = this;
                              self.sendSocketNotification('TEMPERATURE', temp);
              It seems that the MMM-Temperature module is not trying to call the node_helper.js
              Not sure why it doesn’t. Or even if, i don’t know why the node_helper.js doesn’t work.
              Maybe this has something to do with the "sendSocketNotification(‘CONNECT’) ???
              It’s never mentioned in the node_helper.
              • C Offline
                Chiggo
                It works!
                after testing some things PM2 didn’t work anymore, so i recovered from a backup, installed the drivers for the DS18B20 again, copied the scripts back, restarted and it works.
                Don’t know why and how, but it does :smile:
                Solved!
                • P Offline
                  Phate @Chiggo
                  @Chiggo
                  This sounds awesome…
                  Is this downloadable from github?
                  • C Offline
                    Chiggo
                    @Phate
                    No, it’s not available on GitHub. But with the hints from @MichMich it was pretty easy to realize.
                    To load the drivers for the DS18B20 I followed these instructions https://www.kompf.de/weather/pionewiremini.html
                    To get the DS18B20 working with node.js I installed this https://www.npmjs.com/package/ds18x20
                    And finaly I edited the scripts of the systemtemperature-module and it works.
                    Step-by-Step
                    • Add this line to your /boot/config.txt
                    dtoverlay=w1-gpio,gpiopin=4,pullup=on
                    • Add to your /etc/modules following and reboot the Pi
                    w1-gpio pullup=1
                    w1-therm
                    • Note the ID of your sensor (go to /sys/bus/w1/devices and list the files, the ID should look something like this 28-04163746c8ff
                    • Got to /MagicMirror/modules and create a folder named MMM-Temperature
                    • Create a file named MMM-Temperature.js and copy the code from my post for this script
                    • Create a file named node_helper.js and copy the code from my post and change the ID of my sensor to yours (it’s in line 16)
                    • Register this module in your /MagicMirror/config/config.js
                    • Restart your MM and you are done :)
                    Hope I could help. Let me know if it works.
                    • P Offline
                      Phate @Chiggo
                      @Chiggo
                      Mate. That’s just awesome.
                      Few worry spots but sure I can make that happen.
                      I made sure to order the same temp module so hopefully I shouldn’t have trouble.
                      Thanks mate. Awesome.
                      May have questions tho so will yell out of i do when eBay comes thru lol
                      Thanks again
                      • ? Offline
                        A Former User
                        This post is deleted!
