Roomtemperature with DS18B20
11 Posts 4 Posters 7.4k Views 3 Watching
    Chiggo
    Hello everybody,
    I am new to this forum and I am trying to display the roomtemperature with a DS18B20 sensor at my MagicMirrorv2.
    I have installed ‘ds18x20’ to get the temperature using node.js, butit seems to be impossible for me, to display this at my MagicMirror.
    I can read the temp using this commands, and it shows the temp at the console.
    var sensor = require('ds18x20');
    var temp = sensor.get('28-00000574c791');
    console.log(temp);
    I tried to write a module from exsting code to display the temp at the mirror, but everything it shows is this picture
    Here is the code
    /* global Module */
    /* Magic Mirror
     * Module: MMM-Temperature
    Module.register('MMM-Temperature', {
    // Define start sequence.
            start: function() {
                    // Schedule update interval.
                    var self = this;
                    setInterval(function() {
                            self.updateDom();
                    }, 1000);
    // Get temperature.
    tempRead: function() {
            var sensor = require ('ds18x20');
            var temp = sensor.get('28-04163746c8ff');
            return temp;
    // Override dom generator.
            getDom: function() {
    var temperature = this.tempRead();
    var celsius = document.createTextNode(temperature);
    wrapper.appendChild(celsius);
    return wrapper;
    Can someone explain to me, how to get this thing working!?
      MichMich
      What is important to understand, is the difference between the frontend module, and the node_helper.
      The frontend module (yourmodulename.js) is there to make sure the UI works, the node helper (node_helper.js) allows you to execute commands like you want.
      You need to make a module that contains both.
      Check out this very simple example which is pretty easy for you to adapt:
      https://github.com/MichMich/mmm-systemtemperature
        MichMich
        To point you a bit more in the right direction, the node helper should change to something like:
        sendTemperature: function() {
        	this.sendSocketNotification('TEMPERATURE', temp);
          Chiggo
          Thank you for fast reply.
          I will give it a try tomorrow and check if i get it.
          My first steps in JS :sweat_smile:
            Chiggo
            Spend some time to figure out what you mean, but i stuck again.
            Now at this point picture
            Here is the MMM-Temperature.js
                    defaults: {
                            prependString: 'Raumtemperatur: '
                    start: function() {
                            this.temperature = 'fetching...';
                            this.sendSocketNotification('CONNECT');
                    socketNotificationReceived: function(notification, temp) {
                        if (notification === 'TEMPERATURE') {
                            this.temperature = temp;
                            this.updateDom();
                            wrapper.innerHTML = this.config.prependString + this.temperature;
                            return wrapper;
            And here is the node_helper.js
            var NodeHelper = require("node_helper");
                    start: function function_name () {
                            var self = this;
                                    self.sendTemperature();
                            }, 10000);
                            var self = this;
                            self.sendSocketNotification('TEMPERATURE', temp);
            It seems that the MMM-Temperature module is not trying to call the node_helper.js
            Not sure why it doesn’t. Or even if, i don’t know why the node_helper.js doesn’t work.
            Maybe this has something to do with the "sendSocketNotification(‘CONNECT’) ???
            It’s never mentioned in the node_helper.
              Chiggo
              It works!
              after testing some things PM2 didn’t work anymore, so i recovered from a backup, installed the drivers for the DS18B20 again, copied the scripts back, restarted and it works.
              Don’t know why and how, but it does :smile:
              Solved!
              P 1 Reply Last reply Jul 16, 2016, 7:16 PM Reply Quote 0
                Phate @Chiggo
                @Chiggo
                This sounds awesome…
                Is this downloadable from github?
                  Chiggo
                  @Phate
                  No, it’s not available on GitHub. But with the hints from @MichMich it was pretty easy to realize.
                  To load the drivers for the DS18B20 I followed these instructions https://www.kompf.de/weather/pionewiremini.html
                  To get the DS18B20 working with node.js I installed this https://www.npmjs.com/package/ds18x20
                  And finaly I edited the scripts of the systemtemperature-module and it works.
                  Step-by-Step
                  • Add this line to your /boot/config.txt
                  dtoverlay=w1-gpio,gpiopin=4,pullup=on
                  • Add to your /etc/modules following and reboot the Pi
                  w1-gpio pullup=1
                  w1-therm
                  • Note the ID of your sensor (go to /sys/bus/w1/devices and list the files, the ID should look something like this 28-04163746c8ff
                  • Got to /MagicMirror/modules and create a folder named MMM-Temperature
                  • Create a file named MMM-Temperature.js and copy the code from my post for this script
                  • Create a file named node_helper.js and copy the code from my post and change the ID of my sensor to yours (it’s in line 16)
                  • Register this module in your /MagicMirror/config/config.js
                  • Restart your MM and you are done :)
                  Hope I could help. Let me know if it works.
                  P 1 Reply Last reply Jul 22, 2016, 2:05 PM Reply Quote 1
                    Phate @Chiggo
                    @Chiggo
                    Mate. That’s just awesome.
                    Few worry spots but sure I can make that happen.
                    I made sure to order the same temp module so hopefully I shouldn’t have trouble.
                    Thanks mate. Awesome.
                    May have questions tho so will yell out of i do when eBay comes thru lol
                    Thanks again
                      A Former User
