    My Mirror Dashboard - In progress
    10 Posts 5 Posters 9.7k Views 5 Watching
    • P Offline
      Phate
      Trying to sort software side of things first…
      Temp sensor for room temp module on its way… Update to come
      PIR sensor for screen on/off also on its way… Update to come
      Screen and mirror material not yet chosen… weighing the options
      Updates to come… But very happy so far
      Modules:
      • Alert
      • Clock
      • News Feed
      • Weather Current
      • Weather forecast
      • Calendar Module
      • iCloud Module
      • System Temp module
      • P Offline
        Phate
        Another thing I need to ask about or investigate is the emoji…
        As can be seen in screenshot emoji displays on my macbook thru safari but not when displayed straight from the Pi on my tv… hmmmm
        I know this means emoji is NOT supported but have no idea the work involved to implement it…
        No big deal tho… In process of removing emoji from my contacts…
        • P Offline
          Phate
          Want to swap the iCloud module to a local file… Have the local file but can’t make it display… yet
          • C Offline
            co8
            Hi Phate,
            perhpas this could help you for your calendar file.
            https://forum.magicmirror.builders/topic/467/calendar-ics-file-from-local-path/7
            • F Offline
              Fonfon
              what is the module for birthdays ?
              i try to find it !
              • O Offline
                opensky727 @Fonfon
                @Fonfon I want to know also.
                yawnsY 1 Reply Last reply Reply Quote 0
                • yawnsY Offline
                  yawns Moderator @opensky727
                  @opensky727
                  It’s the calendar module loading a calendar with birthdays
                  • O Offline
                    opensky727 @yawns
                    @yawns Okay thanks! But how do i make a birthday calendar?
                    • yawnsY Offline
                      @opensky727
                      Create a calendar, add birthdays as reoccurring events and load it. Or you use a calendar which is already created within your google or microsoft account
                      • O Offline
                        opensky727 @yawns
                        @yawns I did that, thanks!
