    MMM-Flickr - Pull and animate photos from Flickr public feed of photostream
    11 Posts 5 Posters 10.6k Views 5 Watching
    • K Offline
      kapsolas Module Developer
      Description:
      Check out my module to pull images from a public flickr Feed. Since the feed is the based on the public RSS feed, it will only pull the 20 most recent images - this does not require an API_KEY.
      The images will then animate and rotate on the mirror.
      Download:
      [card:kapsolas/MMM-Flickr]
      Initial Version
      • L Offline
        Llama
        Hi no matter what username I use I can’t get this to work? I have tried just my username, whole web address and api? thanks
        • K Offline
          Unfortunately, it does not work with your username. You need to determine what your user id is.
          The way I found my id was to go to my camera roll on flickr, then I did a view page source and looked for the value nsid. following it you will see something with the following pattern: ########@N## It may be ########%40N##
          You id may look a bit different, but the nsid is the value you want to put in to the config.js file.
          • L Offline
            Llama
            @N worked! thanks
            • K Offline
              Glad it worked for ya!
              • P Offline
                PhilReis
                i have a problem with the module.
                I used a public ID but the module show me “Loading…”.
                I find out the ID over the webpage http://idgettr.com/
                Regards,
                Phil
                • K Offline
                  If it shows Loading@ it means that it never made the request to the site.
                  Can you try the URL that is created manually?
                  Have you confirmed you have connectivity from the raspberry pi?
                  • P Offline
                    PhilReis
                    Yes the raspberry pi has connectivity.
                    And the ID is created from the URL which is from a USER.
                    My config is:
                                    module: 'MMM-Flickr',
                                    position: 'bottom_right',
                                            animationSpeed: 2500,
                                            updateInterval: 10000
                    The config is correct, or?
                    • K Offline
                      The config looks good.
                      PhilReis - were you ever able to get this resolved?
                      • F Offline
                        fragator @kapsolas
                        Hello, I can not run this module. I put the right id, it remains on the mirror in ‘loading’
                        Someone can help me please
                        • N Offline
                          nobita @kapsolas
                          @kapsolas when put the user id “xxxxxx@Nxx” in config.js of Flickr module after finish installation
                          have message "no available longer photo " background all photo
                          but I can see my photo in photostream flickr folder
                          What happen? and How to solve it?
                          help me please?
                          another question : Flickr-module want to put API key?
                          because in www.flickr.com : have to put API key and another key
                          Thanks for your kinds
