    MMM-Flickr - Pull and animate photos from Flickr public feed of photostream
    11 Posts 5 Posters 10.1k Views 5 Watching
    • L Offline
      Llama
      Hi no matter what username I use I can’t get this to work? I have tried just my username, whole web address and api? thanks
      • K Offline
        kapsolas Module Developer
        Unfortunately, it does not work with your username. You need to determine what your user id is.
        The way I found my id was to go to my camera roll on flickr, then I did a view page source and looked for the value nsid. following it you will see something with the following pattern: ########@N## It may be ########%40N##
        You id may look a bit different, but the nsid is the value you want to put in to the config.js file.
        • L Offline
          Llama
          @N worked! thanks
          • K Offline
            Glad it worked for ya!
              PhilReis
              i have a problem with the module.
              I used a public ID but the module show me “Loading…”.
              I find out the ID over the webpage http://idgettr.com/
              Regards,
              Phil
              • K Offline
                If it shows Loading@ it means that it never made the request to the site.
                Can you try the URL that is created manually?
                Have you confirmed you have connectivity from the raspberry pi?
                  PhilReis
                  Yes the raspberry pi has connectivity.
                  And the ID is created from the URL which is from a USER.
                  My config is:
                                  module: 'MMM-Flickr',
                                  position: 'bottom_right',
                                          animationSpeed: 2500,
                                          updateInterval: 10000
                  The config is correct, or?
                  • K Offline
                    The config looks good.
                    PhilReis - were you ever able to get this resolved?
                    • F Offline
                      fragator @kapsolas
                      Hello, I can not run this module. I put the right id, it remains on the mirror in ‘loading’
                      Someone can help me please
                      • N Offline
                        nobita @kapsolas
                        @kapsolas when put the user id “xxxxxx@Nxx” in config.js of Flickr module after finish installation
                        have message "no available longer photo " background all photo
                        but I can see my photo in photostream flickr folder
                        What happen? and How to solve it?
                        help me please?
                        another question : Flickr-module want to put API key?
                        because in www.flickr.com : have to put API key and another key
                        Thanks for your kinds
