    Building the Frame
    15 Posts 6 Posters 26.4k Views 6 Watching
      Mitchfarino Module Developer
      Does anyone have any tutorials or diagrams for how they built their frame, along with how to fix the glass/monitor?
      I’m coming to the build phase now, so I’m struggling to picture how I would do this.
      • K Offline
        KirAsh4 Moderator
        My recommendation is to contact a local frame shop, like picture frames. Not only do they often have scrap material that you can have for free, or for dirt cheap, but they can also help you build a frame, or give you pointers on how to do that.
        • P Offline
          Phate @Mitchfarino
          @Mitchfarino
          Exactly same situation. Sorting out software side first but have a 40" tv I’m planning on using now and starting to think about the frame and mirror.
          Got two samples of mirror today to test. One lets a lot of light and colour thru but isn’t very mirror’ie. The other doesn’t let colour thru but still looks Kewl. And looks good enough for normal mirror.
          Frame I thought about metal. Had a google on making frames. Or buying a pre made aluminium tv frame which they make for displays etc.
          Thinking now I’m either gonna use flat bits of wood. Or cornice gyprock type moulding to make straight picture frame. Then mount the tv to that.
          So no glueing of glass/mirror.
          It will go.
          Picture/large painting frame
          Mirror
          Tv
          Some sort of bracket to hold tv
          Tv to wall mount
          I could be way off and I’m sure there’s a heap of ways to do this but this is my latest plan (changes by the hour lol)
          Love to hear what others are thinking.
          Also check out the my build thread. It’s great to see what others have done.
            Mitchfarino Module Developer @Phate
            @Phate I’ve drawn my idea on the back of a scrap of paper, my dad is gonna draw it up for me
            Once I’ve got it, I’ll share it here
              The housing for the monitor and Pi is now done.
              How did you guys go about mounting it to your wall?
              Housing
              Once my glass arrives I just need to fix the front and secure the monitor.
              • Y Offline
                yawns Moderator
                How are you going to mount the mirror to the housing? With some kind of glue? Or are you going to build a frame which holds the mirror glas (like a picture frame) ?
                  Mitchfarino Module Developer @yawns
                  @yawns Yeah, the glass will sit on top of the monitor and the front frame will hold it in to place
                  I’ll then add wood, behind and below the monitor to hold it in place
                    bhepler Module Developer @Mitchfarino
                    @Mitchfarino I did something similar with my mirror. I ended up routing a channel in two pieces that spanned in the interior of the box. The monitor edges fit in the channel and a couple of corner brackets secured each piece to the interior of the box. If you weren’t too concerned with visible screws on the outside of your box, you could skip the corner brackets for driving screws into the monitor supports from the outside.
                    Monitor braces with channels
                      Mitchfarino Module Developer @bhepler
                      @bhepler how did you fix that to wall?
                      I’m struggling to see how you did it from that pic
                        @Mitchfarino Heh. Well, that pic was just for holding the monitor in place. I used a french cleat to mount the mirror on the wall. One piece screws into the wall, the other screws into the edge of the box. You can make one fairly simply or just buy one from a hardware store.
                          @bhepler And it’s strong enough to hold it up?
                          I think that might be the route I’m gonna take to hang mine
                          Any chance of a pic of the back of yours?
                          • C Offline
                            Cato Module Developer
                            I blogged about building MY mirror here: https://catoantonsen.wordpress.com/2016/09/24/magic-mirror-version-1.
                            • Y Offline
                              yawns Moderator
                              Basically like this: https://docs.smart-mirror.io/docs/hardware.html (scroll down to the last but one picture)
                                @Mitchfarino Oh yeah. The cheap-ish french cleat I bought from Home Depot claims to be rated for 100 lbs. If you mount it on a wall stud, you’ll have no problems whatsoever.
                                  @bhepler it’s a dot and dab wall, so I need to go through to the brick (UK)
