    Calendar won't finish loading
    6 Posts 3 Posters 4.2k Views 2 Watching
    • J
      johnpturner8
      I have put in a url (webcal://calendar.google.com/…/basic.ics)
      And the calendar will not load.
      I am running on a raspberry pi b+, so maybe it is because node is outdated?
      Any ideas?
      E 1 Reply Last reply
      • E
        EoF @johnpturner8
        @johnpturner8 Have you tried to access the ics file straight from the pi (through a browser maybe)? Would be the first thing I would test. To see if it can even reach it at all.
        J 1 Reply Last reply
        • J
          johnpturner8 @EoF
          @EoF It wouldn’t connect to the webcal:// address, but when I replaced it with http:// it downloaded the file. I tried replacing it in the config files but it still won’t load
          • J
            johnpturner8
            The default calendar didn’t load either, so it may not be the url.
            • K
              KirAsh4 Moderator
              Please note that Raspberry Pi 1 (any version) is not supported. The software on them is just too damn old. You might be able to run MM¹ on it.
              • J
                johnpturner8 @KirAsh4
                @KirAsh4 I’ve gotten it running in kiosk mode, but the calendar might not work on it. If it doesn’t I’ll just get rid of it.
