    Syntax error
    20 Posts 5 Posters 10.8k Views 5 Watching
    • G Offline
      Gxnfr Ali @Mykle1
      @Mykle1
      that is my confis.js file…but prayer module does not work…
      /* Magic Mirror Config Sample
      • By Michael Teeuw http://michaelteeuw.nl
      • MIT Licensed.
      var config = {
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
      language: "en",
      timeFormat: 24,
      units: "metric",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      	module: 'email',
                  position: 'bottom_left',
                  header: 'Email',
                      accounts: [
                              user: 'xxxxx@gmail.com',
                              password: 'xxxxx',
                              host: 'imap.gmail.com',
                              port: 993,
                              tls: true,
                              authTimeout: 10000,
                              numberOfEmails: 2,
                      fade: true,
                      maxCharacters: 30
      		module: "clock",
      		position: "top_left"
      		header: "PK Holidays",
      					symbol: "calendar-check-o ",
      					url: "webcal://www.officeholidays.com/ics/ics_country_code.php?iso=PK"
      		module: "compliments",
      		position: "lower_third"
      		module: "currentweather",
      			locationID: "1166547",  //ID from http://www.openweathermap.org/help/city_list.txt
      			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
      		module: "weatherforecast",
      		header: "Weather Forecast",
      			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
      		module: 'MMM-PrayerTime',
      		position: 'top_left',
      			apiVersion: '1.0',
      			lat: '30.6612',
      			lon: '73.1086',
      			timezone: 'Asia/Karachi',
      			method: 4,
      			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
      			notDisplayed: ['midnight', 'sunset'],
      			useUpdateInterval: true,
      			updateInterval: 86400 * 1000,
      			animationSpeed: 2.5 * 1000,
      			language: config.language,
      			showAdzanAlert: true,
      			alertTimer: 15000
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "New York Times",
      					url: "https://news.google.com/news/rss/local?ned=en_pk&hl=en&gl=US"
      			showSourceTitle: true,
      			showPublishDate: true
      if (typeof module !== “undefined”) {module.exports = config;}
      • cowboysdudeC Offline
        cowboysdude Module Developer
        @Gxnfr-Ali said in Syntax error:
        there’s a problem in this line…take it out and what’s below is valid according to this site:
        http://esprima.org/demo/validate.html
        as for the prayer module not working you should post in that topic and get help with that as I’m not sure why it’s not working.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        	modules: [{
        			module: "alert",
        			position: "top_bar"
        			module: 'email',
        			header: 'Email',
        				accounts: [{
        					password: 'xxxxx',
        					port: 993,
        					tls: true,
        					authTimeout: 10000,
        					numberOfEmails: 2,
        				fade: true,
        				maxCharacters: 30
        			module: "clock",
        				calendars: [{
        				apiVersion: '1.0',
        				lat: '30.6612',
        				lon: '73.1086',
        				method: 4,
        				alertTimer: 15000
        			module: "newsfeed",
        				feeds: [{
        • G Offline
          Gxnfr Ali @cowboysdude
          @cowboysdude
          hi
          can u help me?
            cowboysdude Module Developer @Gxnfr Ali
            @Gxnfr-Ali I just did …the config I posted is valid and should work :)
            The prayer module you will have to get help in that topic for it… I don’t know that module :)
            What exactly do you need help with? :)
            G 2 Replies Last reply Reply Quote 0
            • G Offline
              @cowboysdude okay and thanks
              • G Offline
                @cowboysdude
                what module you can magicmirror done?
                  @Gxnfr-Ali I’m not sure what you mean
                  G 3 Replies Last reply Reply Quote 0
                  • G Offline
                    This post is deleted!
                    • G Offline
                      @cowboysdude sir
                      • G Offline
                        @cowboysdude can you help me in MMM-NOAA and MMM-awesome-alexa
