    Syntax error
    20 Posts 5 Posters 12.3k Views 5 Watching
    • cowboysdudeC Offline
      The config isn’t working. I had to change this:
      language: config.language,
      TO:
      language: “en”,
      and this:
      timezone: true,
      to
      timezone: ‘EST’
      and it worked… so change your language and timezone that should make it work :)
      Here is an example: [the lon and lat are JUST examples, use yours].
      module: ‘MMM-PrayerTime’,
      position: ‘top_left’,
      top_left/top_right.
      apiVersion: ‘1.0’,
      lat: 12.089796,
      lon: -56.807734,
      timezone: ‘EST’,
      method: 5,
      playAdzan: [‘fajr’, ‘dhuhr’, ‘asr’, ‘maghrib’, ‘isha’],
      notDisplayed: [‘midnight’, ‘sunset’],
      useUpdateInterval: true,
      updateInterval: 86400 * 1000,
      animationSpeed: 2.5 * 1000,
      language: “en”,
      showAdzanAlert: true,
      alertTimer: 15000
        arifms
        Hi cowboysdude;
        Appreciate your assistance.
        I copied the example as provided, editign the lat, long & timezone to suit mine, however it still throws error.
        carefully checked the code, noted an extra line after position, removed the same.
        tried running again, with no luck.
        changed my timezone on pi to UTC from Asia/Dubai and same in to the code, still no result.
        it throws error as below;
        Starting MagicMirror: v2.1.1
        Loading config …
        WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
        Loading module helpers …
        No helper found for module: helloworld.
        All module helpers loaded.
        Starting server on port 8080 …
        Starting server op port 8080 …
        Server started …
        Sockets connected & modules started …
        Launching application.
          Post your config file for me so I can look at it :)
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @arifms
            @arifms if you copied the config from @cowboysdude you are using the wrong quotes replace all quotes with either ' or ", because backticks don’t work
              I just linted his config and sent it to him pm…
                arifms
                @ strawberry
                Thanks for pointing out the error.
                all working good now.
                @cowboysdude edited the app id’s thanks again for pointing it out.
                Cheers
                  cowboysdude Module Developer @arifms
                  @arifms said in Syntax error:
                  @ strawberry
                  Cheers
                  Yeah my fault… it doesn’t copy to the forum… it changes the quotes… sorry about that. Been up since 4 not enough tea yet ;)
                  • G Offline
                    Gxnfr Ali @Mykle1
                    @Mykle1
                    that is my confis.js file…but prayer module does not work…
                    /* Magic Mirror Config Sample
                    • MIT Licensed.
                    var config = {
                    port: 8080,
                    ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
                    language: "en",
                    timeFormat: 24,
                    units: "metric",
                    		module: "alert",
                    		module: "updatenotification",
                    		position: "top_bar"
                    	module: 'email',
                                position: 'bottom_left',
                                header: 'Email',
                                    accounts: [
                                            user: 'xxxxx@gmail.com',
                                            password: 'xxxxx',
                                            host: 'imap.gmail.com',
                                            port: 993,
                                            tls: true,
                                            authTimeout: 10000,
                                            numberOfEmails: 2,
                                    fade: true,
                                    maxCharacters: 30
                    		module: "clock",
                    		position: "top_left"
                    		header: "PK Holidays",
                    					symbol: "calendar-check-o ",
                    					url: "webcal://www.officeholidays.com/ics/ics_country_code.php?iso=PK"
                    		module: "compliments",
                    		position: "lower_third"
                    		module: "currentweather",
                    			locationID: "1166547",  //ID from http://www.openweathermap.org/help/city_list.txt
                    			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
                    		module: "weatherforecast",
                    		header: "Weather Forecast",
                    			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                    		module: 'MMM-PrayerTime',
                    		position: 'top_left',
                    			apiVersion: '1.0',
                    			lat: '30.6612',
                    			lon: '73.1086',
                    			timezone: 'Asia/Karachi',
                    			method: 4,
                    			playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                    			notDisplayed: ['midnight', 'sunset'],
                    			alertTimer: 15000
                    		module: "newsfeed",
                    		position: "bottom_bar",
                    			feeds: [
                    					title: "New York Times",
                    					url: "https://news.google.com/news/rss/local?ned=en_pk&hl=en&gl=US"
                    			showSourceTitle: true,
                    			showPublishDate: true
                    if (typeof module !== “undefined”) {module.exports = config;}
                      @Gxnfr-Ali said in Syntax error:
                      there’s a problem in this line…take it out and what’s below is valid according to this site:
                      http://esprima.org/demo/validate.html
                      as for the prayer module not working you should post in that topic and get help with that as I’m not sure why it’s not working.
                      var config = {
                      	port: 8080,
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      	modules: [{
                      			module: "alert",
                      			position: "top_bar"
                      			module: 'email',
                      			header: 'Email',
                      				accounts: [{
                      					password: 'xxxxx',
                      					port: 993,
                      					tls: true,
                      					authTimeout: 10000,
                      					numberOfEmails: 2,
                      				fade: true,
                      				maxCharacters: 30
                      			module: "clock",
                      				calendars: [{
                      				apiVersion: '1.0',
                      				lat: '30.6612',
                      				lon: '73.1086',
                      				method: 4,
                      				alertTimer: 15000
                      			module: "newsfeed",
                      				feeds: [{
                      • G Offline
                        Gxnfr Ali @cowboysdude
                        @cowboysdude
                        hi
                        can u help me?
                          cowboysdude Module Developer @Gxnfr Ali
                          @Gxnfr-Ali I just did …the config I posted is valid and should work :)
                          The prayer module you will have to get help in that topic for it… I don’t know that module :)
                          What exactly do you need help with? :)
                          G 2 Replies Last reply Reply Quote 0
                          • G Offline
                            @cowboysdude okay and thanks
                            • G Offline
                              @cowboysdude
                              what module you can magicmirror done?
                                @Gxnfr-Ali I’m not sure what you mean
                                G 3 Replies Last reply Reply Quote 0
                                • G Offline
                                  • G Offline
                                    @cowboysdude sir
                                    • G Offline
                                      @cowboysdude can you help me in MMM-NOAA and MMM-awesome-alexa
