    Syntax error
    20 Posts 5 Posters 10.1k Views 5 Watching
      arifms
      Re: MMM-PrayerTime
      How to change the language. npm start throws syntax error
      “WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read property ‘language’ of undefined”
      please guide to correct format
        Mykle1 Project Sponsor Module Developer @arifms
        @arifms
        I assume that your mirror was working until you added MMM-PrayerTime to your config.js. So, please post your config.js here.
          arifms
          Yes Exactly MM was working as required until i added the MMM-PrayerTime. As reuested below is the config.js
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          		module: 'email',
                          position: 'bottom_left',
                          header: 'Email',
                              accounts: [
                                      user: 'xxxxx@gmail.com',
                                      password: 'xxxxx',
                                      host: 'imap.gmail.com',
                                      port: 993,
                                      tls: true,
                                      authTimeout: 10000,
                                      numberOfEmails: 2,
                              fade: true,
                              maxCharacters: 30
          			module: 'MMM-PrayerTime',
          			position: 'top_left',
          				apiVersion: '1.0',
          				lat: 25.258169,
          				lon: 55.304722,
          				timezone: true,
          				method: 4,
          				playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
          				notDisplayed: ['midnight', 'sunset'],
          				useUpdateInterval: true,
          				updateInterval: 86400 * 1000,
          				animationSpeed: 2.5 * 1000,
          				language: config.language,
          				showAdzanAlert: true,
          				alertTimer: 15000
          			module: "alert",
          			module: 'MMM-ModuleScheduler'
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "UAE Holidays",
          						symbol: "calendar-check-o ",
          						url: "webcal://www.calendarlabs.com/templates/ical/UAE-Holidays.ics"
          			module: "compliments",
          			position: "lower_third"
          			module: "currentweather",
          				locationID: "292223",  //ID from http://www.openweathermap.org/help/city_list.txt
          				appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "New York Times",
          				showSourceTitle: true,
          				showPublishDate: true
          • cowboysdudeC Offline
            The config isn’t working. I had to change this:
            TO:
            language: “en”,
            and this:
            timezone: true,
            to
            timezone: ‘EST’
            and it worked… so change your language and timezone that should make it work :)
            Here is an example: [the lon and lat are JUST examples, use yours].
            module: ‘MMM-PrayerTime’,
            position: ‘top_left’,
            top_left/top_right.
            apiVersion: ‘1.0’,
            lat: 12.089796,
            lon: -56.807734,
            timezone: ‘EST’,
            method: 5,
            playAdzan: [‘fajr’, ‘dhuhr’, ‘asr’, ‘maghrib’, ‘isha’],
            notDisplayed: [‘midnight’, ‘sunset’],
            language: “en”,
            alertTimer: 15000
              arifms
              Hi cowboysdude;
              Appreciate your assistance.
              I copied the example as provided, editign the lat, long & timezone to suit mine, however it still throws error.
              carefully checked the code, noted an extra line after position, removed the same.
              tried running again, with no luck.
              changed my timezone on pi to UTC from Asia/Dubai and same in to the code, still no result.
              it throws error as below;
              Starting MagicMirror: v2.1.1
              Loading config …
              WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
              Loading module helpers …
              No helper found for module: helloworld.
              All module helpers loaded.
              Starting server on port 8080 …
              Starting server op port 8080 …
              Server started …
              Sockets connected & modules started …
              Launching application.
                Post your config file for me so I can look at it :)
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @arifms
                  @arifms if you copied the config from @cowboysdude you are using the wrong quotes replace all quotes with either ' or ", because backticks don’t work
                    I just linted his config and sent it to him pm…
                      arifms
                      @ strawberry
                      Thanks for pointing out the error.
                      all working good now.
                      @cowboysdude edited the app id’s thanks again for pointing it out.
                      Cheers
                        cowboysdude Module Developer @arifms
                        @arifms said in Syntax error:
                        @ strawberry
                        Cheers
                        Yeah my fault… it doesn’t copy to the forum… it changes the quotes… sorry about that. Been up since 4 not enough tea yet ;)
