    This might be a daft question, but...
    27 Posts 6 Posters 19.9k Views 5 Watching
    • MitchfarinoM Offline
      Mitchfarino Module Developer
      Sorry, again
      Which of these projects would be the correct one?!
        alexyak @Mitchfarino
        @Mitchfarino Sorry, I’ve not tried this yet myself, but have you tried to use this option that you have selected: “From Existing Node.js code”?
        MitchfarinoM 1 Reply Last reply Reply Quote 0
          Mitchfarino Module Developer @alexyak
          @alexyak Sorted, I tried that and imported an existing module
          Now I just to figure out what I’m doing now! :)
            OK, I’m up and running, but I’m not sure how to parse my JSON result in to html.
            I have this, but don’t know whether it’s correct
            I just want to see if I can list the names from the results of my GET request
            getDom: function () {
                $.getJSON(this.url,
                    function (data) {
                        var tr;
                        for (var i = 0; i < data.length; i++) {
                            tr = $('<tr/>');
                            tr.append("<td>" + data[i].name + "</td>");
                            $('table').append(tr);
                        wrapper.append("<td>" + data[i].name + "</td>");
                return wrapper;
            I’d like to note, this is all completely new to me, so I’m trying to learn as I go…
              @strawberry-3-141 I saw you were online, so I’m shamelessly tagging you in my post in the hopes of some guidance :-(
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @Mitchfarino
                @Mitchfarino
                    var table = document.createElement("table");
                    $.getJSON(this.url,
                        function (data) {
                                var row = document.createElement("tr");
                                var name = document.createElement("td");
                                name.innerHTML = data[i].name;
                                row.appendChild(name);
                                table.appendChild(row);
                            wrapper.appendChild(table);
                            return wrapper;
                but I’m pretty sure that this will not work, because the return is in an asynchronous callback, i would do a different structure call your url in an interval somewhere else and save your data into an module variable and call the updateDom function after a result, then in getDom you iterate over the data.
                  Mitchfarino Module Developer @strawberry 3.141
                  @strawberry-3.141 Thanks very much, I’ll have a play with it over the weekend and hopefully I get can something working
                  I’ve not done anything like this before really, so just jumping in and seeing what happens :-)
                    @Mitchfarino
                    url: "", //Insert your url here
                    result: false,
                    defaults: {
                        updateInterval: 30 * 60 * 1000 //Every 30 mins
                    start: function(){
                        this.getData();
                        setInterval(()=>{
                            this.getData();
                        }, this.config.updateInterval);
                    getDom: function() {
                        if(this.result){
                            for (var i = 0; i < this.result.length; i++) {
                                name.innerHTML = this.result[i].name;
                        } else {
                            wrapper.innerHTML = "No data to show!";
                        return wrapper;
                    getData: function(){
                        $.getJSON(this.url, (data) => {
                            this.result = data;
                            this.updateDom();
                    MitchfarinoM 1 Reply Last reply Reply Quote 1
                      @strawberry-3.141 Thanks for this, I’ll see if I can get it working
                        Mitchfarino Module Developer @Mitchfarino
                        @strawberry-3-141 once I’ve got some code, how do I test it on my mirror?
                        Just copy the folder to the modules folder and add it to the config, or is there something else I need to do?
                        paviroP 1 Reply Last reply Reply Quote 0
                        • 2 / 3
