    VoiceControl module
    79 Posts 27 Posters 112.9k Views 29 Watching
      alexyak @tyho
      @tyho said in VoiceControl module:
      notificationReceived
      You can put it in any other module that you would like to react on the voice command and then just call self.updateDom(self.config.animationSpeed);
      • T Offline
        tyho
        Wow! @alexyak nice work. I got it running. and i am playing around with it.
        1 question:
        I want to display the commands i said for 3 seconds.
        If i say a command i can get the text with:
        this.config.text = “going to sleep…”;
        this.updateDom(this.config.animationSpeed);
        Is there a way to auto reset it to default/hide after a few seconds? (i am trying this for hours already ^^)
          alexyak @tyho
          @tyho, you can use setTimeout function to wait a for few seconds and then reset the text value. Something like that:
          var self = this;
          setTimeout(function(){
          self.config.text = “”;
          self.updateDom …
          }, 3000);
          • T Offline
            tyho
            thanks again it’s working :)
            i made a notification.js:
            notificationReceived: function(notification, payload, sender) {
            		var self = this;
            				if (notification === "go_to_sleep"){
                        		this.config.text = "going to sleep...";
            						self.config.text = "";
            					}, 3000);
            				if (notification === "wake_up"){
                        		this.config.text = "waking up...";
            					}, 3000);
            i have made a node_helper.js:
            const NodeHelper = require('node_helper');
            const exec = require('child_process').exec;
              start: function () {
            	      this.started = false
                if (notification === 'go_to_sleep' && this.started == false) {
                        exec("/opt/vc/bin/tvservice -o", null);
            	    if (notification === 'wake_up' && this.started == false) {
                        exec("/opt/vc/bin/tvservice -p", null);
            It shows the command i speak for 3 seconds. But i can’t get the node helper working to actualy turn on and off my monitor. How can i bind this 2 modules? Or do i have to include it as a separate js file?
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @tyho
              @tyho try this.sendSocketNotification('go_to_sleep', {}); in notification.js otherwise the node_helper doesnt’t get any msg and will not perform any action
              • T Offline
                tyho
                Great! it’s working! thanks!
                • T Offline
                  tyho
                  I still have a little problem. I want to register that if the monitor is on or off. It’s working very well except on the autosleep function that is loaded in the node_helper.
                  My notification.js
                  var awake = 1;
                  Module.register("notification",{
                  	// Default module config.
                  	defaults: {
                  		text: "",
                  		animationSpeed: 500,
                  	notificationReceived: function(notification, callback) {
                  		var self = this;
                  				if (notification === "go_to_sleep" && awake === 1){
                  						self.sendSocketNotification('go_to_sleep', {});
                  					}, 1000);
                  					awake = 0;
                  					callback(awake);
                  				if (notification === "wake_up" && awake === 0){
                  					this.sendSocketNotification('wake_up', {});
                  					}, 5000);
                  					awake = 1;
                  					callback(awake);
                  				if (notification === "autosleep"){
                  					awake = 0;
                  					callback(awake);
                  	// Override dom generator.
                  	getDom: function() {
                  		wrapper.innerHTML = this.config.text;
                  		return wrapper;
                  and my node_helper.js
                  'use strict';
                  var timer;
                  function initialize() {
                  (function(){
                  	initialize();
                  			autosleep();
                  function autosleep(){
                  	  timer=setTimeout(function(){
                  		  	var self = this;
                  				self.sendSocketNotification('autosleep');
                  			},  10*60*1000);
                    socketNotificationReceived: function(notification) {
                      if (notification === 'go_to_sleep') {
                  			clearTimeout(timer);
                  	if (notification === 'wake_up') {
                  			exec("/bin/fbset -depth 8 && /bin/fbset -depth 16 ", null);
                        		exec("/usr/bin/xrefresh",null);
                  			autosleep();
                  what i want is: if the autosleep function turns my monitor off, the variable awake in the notification.js set to 0.
                  any other suggestion on junky code are also welcome ^^
                    alexyak
                    If you override socketNotificationReceived in your module then you should receive the message from node_helper and can reset your flag appropriately.
                    • T Offline
                      tyho @alexyak
                      @alexyak how to override that module? I already call it with notifications === ‘autosleep’. And that notification gets send by the node_helper right? what am i missing?
                        alexyak @tyho
                        @tyho What I meant is you need to add socketNotificationReceived to your module notification.js.
                        • 6
                        • 7
                        • 8
                        • 7 / 8
