    VoiceControl module
    79 Posts 27 Posters 126.3k Views 29 Watching
    • T
      tyho
      where to place “notificationReceived: function” to get a text output on the mirror?
      A 1 Reply Last reply
      • A
        alexyak @tyho
        @tyho said in VoiceControl module:
        You can put it in any other module that you would like to react on the voice command and then just call self.updateDom(self.config.animationSpeed);
        • T
          tyho
          Wow! @alexyak nice work. I got it running. and i am playing around with it.
          1 question:
          I want to display the commands i said for 3 seconds.
          If i say a command i can get the text with:
          this.config.text = “going to sleep…”;
          this.updateDom(this.config.animationSpeed);
          Is there a way to auto reset it to default/hide after a few seconds? (i am trying this for hours already ^^)
          • A
            alexyak @tyho
            @tyho, you can use setTimeout function to wait a for few seconds and then reset the text value. Something like that:
            var self = this;
            setTimeout(function(){
            self.config.text = “”;
            self.updateDom …
            }, 3000);
            • T
              tyho
              thanks again it’s working :)
              i made a notification.js:
              		var self = this;
              				if (notification === "go_to_sleep"){
                          		this.config.text = "going to sleep...";
              						self.config.text = "";
              					}, 3000);
              				if (notification === "wake_up"){
                          		this.config.text = "waking up...";
              					}, 3000);
              i have made a node_helper.js:
              const NodeHelper = require('node_helper');
              const exec = require('child_process').exec;
                start: function () {
              	      this.started = false
                  if (notification === 'go_to_sleep' && this.started == false) {
                          exec("/opt/vc/bin/tvservice -o", null);
              	    if (notification === 'wake_up' && this.started == false) {
                          exec("/opt/vc/bin/tvservice -p", null);
              It shows the command i speak for 3 seconds. But i can’t get the node helper working to actualy turn on and off my monitor. How can i bind this 2 modules? Or do i have to include it as a separate js file?
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @tyho
                @tyho try this.sendSocketNotification('go_to_sleep', {}); in notification.js otherwise the node_helper doesnt’t get any msg and will not perform any action
                • T
                  tyho
                  Great! it’s working! thanks!
                  • T
                    tyho
                    I still have a little problem. I want to register that if the monitor is on or off. It’s working very well except on the autosleep function that is loaded in the node_helper.
                    My notification.js
                    var awake = 1;
                    Module.register("notification",{
                    	// Default module config.
                    	defaults: {
                    		text: "",
                    		animationSpeed: 500,
                    	notificationReceived: function(notification, callback) {
                    		var self = this;
                    				if (notification === "go_to_sleep" && awake === 1){
                    						self.sendSocketNotification('go_to_sleep', {});
                    					}, 1000);
                    					awake = 0;
                    					callback(awake);
                    				if (notification === "wake_up" && awake === 0){
                    					this.sendSocketNotification('wake_up', {});
                    					}, 5000);
                    					awake = 1;
                    					callback(awake);
                    				if (notification === "autosleep"){
                    					awake = 0;
                    					callback(awake);
                    	// Override dom generator.
                    	getDom: function() {
                    		wrapper.innerHTML = this.config.text;
                    		return wrapper;
                    and my node_helper.js
                    'use strict';
                    var timer;
                    function initialize() {
                    (function(){
                    	initialize();
                    			autosleep();
                    function autosleep(){
                    	  timer=setTimeout(function(){
                    		  	var self = this;
                    				self.sendSocketNotification('autosleep');
                    			},  10*60*1000);
                      socketNotificationReceived: function(notification) {
                        if (notification === 'go_to_sleep') {
                    			clearTimeout(timer);
                    	if (notification === 'wake_up') {
                    			exec("/bin/fbset -depth 8 && /bin/fbset -depth 16 ", null);
                          		exec("/usr/bin/xrefresh",null);
                    			autosleep();
                    what i want is: if the autosleep function turns my monitor off, the variable awake in the notification.js set to 0.
                    any other suggestion on junky code are also welcome ^^
                    • A
                      alexyak
                      If you override socketNotificationReceived in your module then you should receive the message from node_helper and can reset your flag appropriately.
                      T 1 Reply Last reply
                      • T
                        tyho @alexyak
                        @alexyak how to override that module? I already call it with notifications === ‘autosleep’. And that notification gets send by the node_helper right? what am i missing?
                        • A
                          alexyak @tyho
                          @tyho What I meant is you need to add socketNotificationReceived to your module notification.js.
                          • T
                            tyho
                            @alexyak i can’t get it to work. it tested:
                            It sends sockets notifications from notifications.js to node_helper.js. But not from node_helper.js back to notifications.js.
                            Even if i put it in the start function of the node_helper.js:
                            start: function() {
                              this.sendSocketNotification("autosleep", {});
                            it won’t get received it my notification.js:
                               if (notification === "autosleep") {
                            	  alert("autosleep received");
                            		awake = 0;
                            any idea? is it even possible to use it backwards?
                            • A
                              alexyak
                              Try to put a call in your start method of the module (notification.js) to establish the connection with node_helper. Something like that:
                              this.sendSocketNotification(“CONNECT”, {});
                              • A
                                alexyak
                                I’ve updated the VoiceControl module to display a list of commands on the mirror:
                                [ card : alexyak/voicecontrol ]
                                • A
                                  alexyak
                                  [card:alexyak/voicecontrol]
                                    brumoeller
                                    This is a really cool module. Does anyone know a good microphone that will work for the whole room? The mic I have only works when you are close.
                                    • G
                                      gismo2006
                                      @alexyak sorry, but i have a little Problem. Maybe you can help me.
                                      You write on Github in your Readme file, I have to put the code (notificationReceived: function(notification, payload, sender)…) into the module to use it. I like to controll the module Simple music player by @EoF so i clone your github files copy the code into the config.js File train and download a pmdl file. But where should i paste the code notificationReceived: function(notification, payload, sender)… In the config.js File or in the mmm-music-player.js file in folder modules simple music Player?
                                      Sorry i’m new in the coding world, and now a little bit confused :-D
                                      Greets gismo2006
                                      J 1 Reply Last reply
                                        Jopyth Moderator @gismo2006
                                        @gismo2006 This part has to go into mm-music-player.js. This is where you receive the notification. Then instead of this.media.play() you have to do access the play and stop functions of the mm-music-player (which unfortunately is seems a little bit complicated, since they are only elements on the web page).
                                        Edit: Maybe the easiest is to give the Play and Stop button an id and then ‘fake’ a click event on the the buttons.
                                        var playButton = document.getElementById('play-button');
                                        playButton.click();
                                        • G
                                          gismo2006
                                          Hi @Jopyth thank you for your helping.
                                          But I think i’m to stupid… :-(
                                          I have copy your first code line into the mm-music-player.js file. But now the module isn’t shown at the mirror. But the mirror shows all other module i installed at the same time… (I use pavrios Facial-Recogination module) If I cut out your line the mirrors behaviour is like it should be. On searching my misstake i found a line called: var playButton = document.createElement(“div”);. I cut this line and put in your line but nothing.
                                          greets gismo
                                            @gismo2006 Have you put this into the notificationReceived function, e.g. in line 26?
                                                    if (notification === "PLAY_MUSIC"){
                                                            playButton.click();
                                                    if (notification === "STOP_MUSIC"){
                                                            var stopButton = document.getElementById('stop-button');
                                                            stopButton.click();
                                            Also add the id somewhere here, e.g. with
                                            playButton.id = 'play-button'
                                            Same for the stop button.
                                            • 1 / 4
