    VoiceControl module
    79 Posts 27 Posters 113.8k Views 29 Watching
    • F Offline
      frodrd00 @GinSeng
      Hi @GinSeng ,
      How can I change the volume with the voice?
      if (notification === “VOLUME_UP”){
      if (notification === “VOLUME_DOWN”){
      Thanks.
      • G Offline
        GinSeng
        @frodrd00 Hey sorry i didn’t try this. Maybe i find time in the Christmas vacations but exams are near so i can’t promise you :P
          Jeff @GinSeng
          @GinSeng said in VoiceControl module:
          greez GinSeng
          Thanks for the great instructions, but I think my mic isn’t working correctly :(
          I think I have to order a new one first.
            shashank @Jeff
            @Jeff hi, i wanted to share my Mirror with Family for individual Email on MM, can it be possible to use voice and access individual emails, making the previous person email hide and show the other member email
              DevilRev
              Is there a way to set a snowboy tolerance?
              Because even tho my command is 5 words long it gets triggered all the time when I talk normally with a friend or watch a TV show.
                DevilRev
                So, I found out that there is a sensitivity setting which can be changed in one of the snowboy configs permanently but it can also be controlled for each hotword individually.
                It would be a great feature if we could set a sensitivity for each hotword in the normal config file, if you find the time i would be really thankful for this addition.
                • MedoM Offline
                  Medo
                  Searching for endless hours now, but no solution in sight…
                  Im trying to trigger the mm-music-player module with this voicecontrol module (i say “MUSIK ON” and the mm-music-player starts a certain mp3 file). But no luck…
                  My microfone can record audio (tested with arecord …) …
                  (note: i had to change my “sudo nano /usr/share/alsa/alsa.conf” and the entries “defaults.ctl.card 1” and “defaults.pcm.card 1” from “0” to “1” to get my USB microphone working/recording)
                  …and my mp3 soundfile can be played (tested with “omxplayer -o hdmi …”) - and also if i click on the mm-music-player-module…
                  pm2 logs mm (after a reboot) shows this:
                  [STREAMING] Now streaming realtime logs for [mm] process
                  0|mm | ALSA lib pcm_dmix.c:1022:(snd_pcm_dmix_open) unable to open slave
                  0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
                  0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
                  0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
                  0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
                  0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
                  0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
                  0|mm | ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
                  0|mm | Cannot connect to server socket err = No such file or directory
                  0|mm | Cannot connect to server request channel
                  0|mm | jack server is not running or cannot be started
                  0|mm | Expression ‘paInvalidSampleRate’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2048
                  0|mm | Expression ‘PaAlsaStreamComponent_InitialConfigure( &self->capture, inParams, self->primeBuffers, hwParamsCapture, &realSr )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2719
                  0|mm | Expression ‘PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2843
                  0|mm | Traceback (most recent call last):
                  0|mm | File “./modules/voicecontrol/snowboy/kws-multiple.py”, line 34, in
                  0|mm | detector = snowboydecoder.HotwordDetector(models, sensitivity=sensitivity)
                  0|mm | File “/home/pi/MagicMirror/modules/voicecontrol/snowboy/snowboydecoder.py”, line 115, in init
                  0|mm | stream_callback=audio_callback)
                  0|mm | File “/usr/lib/python2.7/dist-packages/pyaudio.py”, line 747, in open
                  0|mm | stream = Stream(self, *args, **kwargs)
                  0|mm | File “/usr/lib/python2.7/dist-packages/pyaudio.py”, line 442, in init
                  0|mm | self._stream = pa.open(**arguments)
                  0|mm | IOError: [Errno Invalid sample rate] -9997
                  I…
                  • installed the voicecontrol and mm-music-player
                  • double checked the code
                  • changed the mp3 file with another
                  • implemented the code like “GinSeng” stated some lines above.
                  • created the hotwords over at snowboy and copied them to “/MagicMirror”, “voicecontrol” and “mm-music-player” directories
                    But im not able to find the problem…
                  Any suggestions?
                  Thanks a lot for your help…
                  • thereisnotry87T Offline
                    thereisnotry87
                    Hello guys, it seems I have the same problem as @frodrd00 and @Medo and cannot properly run the voicecontrol module. In my case I want to use the camera module which works together with the mentioned one. I’ve checked the voicemodule.js to match with its corresponding declaration in config.js and everything looks fine.
                    **config.js**
                        	module: 'voicecontrol',
                        	position: 'bottom_left',
                            	models: [
                                    	keyword: "Show Camera",
                                    	description: "Say 'Show Camera' to display camera",
                                    	file: "ShowCamera.pmdl",
                                    	message: "SHOW_CAMERA"
                                    	keyword: "Hide Camera",
                                    	description: "Say 'Hide Camera' to hide camera",
                                    	file: "HideCamera.pmdl",
                                    	message: "HIDE_CAMERA"
                                    	keyword: "Selfie",
                                    	description: "Say 'Selfie' when camera is visible",
                                    	file: "Selfie.pmdl",
                                    	message: "SELFIE"
                    voicecontrol.js
                    models: [
                    		keyword: "Selfie",
                    		message: "SELFIE"
                    How did you manage this problem?
                    Thanks a lot in advance ))
                      shashank @thereisnotry87
                      @thereisnotry87 hi, no need to mention voicecontrol commands in config.js file, just mention only as below , make sure you have installed
                      sudo apt-get install python-pyaudio python3-pyaudio sox
                      and
                      copy all pmdl files in MM root folder
                      	    position: 'top_left',
                      go to /usr/share/alsa/alsa.conf and change 0 to 1 in below parameters
                      defaults.ctl.card 1
                      defaults.pcm.card 1,
                      this worked for me.
                        shramik49
                        hi,
                        i am having difficulty in adding voicecontrol module on my magic mirror.
                        i want to use voicecontrol to use camera.
                        so can someone help me with the steps to follow?
                        • 6
                        • 7
                        • 8
                        • 6 / 8
