    VoiceControl module
    79 Posts 27 Posters 112.8k Views 29 Watching
    • T Offline
      tyho
      I still have a little problem. I want to register that if the monitor is on or off. It’s working very well except on the autosleep function that is loaded in the node_helper.
      My notification.js
      var awake = 1;
      Module.register("notification",{
      	// Default module config.
      	defaults: {
      		text: "",
      		animationSpeed: 500,
      	notificationReceived: function(notification, callback) {
      		var self = this;
      				if (notification === "go_to_sleep" && awake === 1){
                  		this.config.text = "going to sleep...";
      					this.updateDom(this.config.animationSpeed);
      					setTimeout(function(){
      						self.sendSocketNotification('go_to_sleep', {});
      						self.config.text = "";
      						self.updateDom(self.config.animationSpeed);
      					}, 1000);
      					awake = 0;
      					callback(awake);
      				if (notification === "wake_up" && awake === 0){
      					this.sendSocketNotification('wake_up', {});
                  		this.config.text = "waking up...";
      					}, 5000);
      					awake = 1;
      					callback(awake);
      				if (notification === "autosleep"){
      					awake = 0;
      					callback(awake);
      	// Override dom generator.
      	getDom: function() {
      		wrapper.innerHTML = this.config.text;
      		return wrapper;
      and my node_helper.js
      'use strict';
      const NodeHelper = require('node_helper');
      const exec = require('child_process').exec;
      var timer;
      function initialize() {
      (function(){
      	initialize();
      			autosleep();
      function autosleep(){
      	  timer=setTimeout(function(){
      		  	var self = this;
      				exec("/opt/vc/bin/tvservice -o", null);
      				self.sendSocketNotification('autosleep');
      			},  10*60*1000);
        start: function () {
        socketNotificationReceived: function(notification) {
          if (notification === 'go_to_sleep') {
      			clearTimeout(timer);
      	if (notification === 'wake_up') {
                  exec("/opt/vc/bin/tvservice -p", null);
      			exec("/bin/fbset -depth 8 && /bin/fbset -depth 16 ", null);
            		exec("/usr/bin/xrefresh",null);
      			autosleep();
      what i want is: if the autosleep function turns my monitor off, the variable awake in the notification.js set to 0.
      any other suggestion on junky code are also welcome ^^
        alexyak
        If you override socketNotificationReceived in your module then you should receive the message from node_helper and can reset your flag appropriately.
        • T Offline
          tyho @alexyak
          @alexyak how to override that module? I already call it with notifications === ‘autosleep’. And that notification gets send by the node_helper right? what am i missing?
            alexyak @tyho
            @tyho What I meant is you need to add socketNotificationReceived to your module notification.js.
            • T Offline
              tyho
              @alexyak i can’t get it to work. it tested:
              It sends sockets notifications from notifications.js to node_helper.js. But not from node_helper.js back to notifications.js.
              Even if i put it in the start function of the node_helper.js:
              start: function() {
                this.sendSocketNotification("autosleep", {});
              it won’t get received it my notification.js:
                 if (notification === "autosleep") {
              	  alert("autosleep received");
              		awake = 0;
              any idea? is it even possible to use it backwards?
                alexyak
                Try to put a call in your start method of the module (notification.js) to establish the connection with node_helper. Something like that:
                this.sendSocketNotification(“CONNECT”, {});
                  alexyak
                  I’ve updated the VoiceControl module to display a list of commands on the mirror:
                  [ card : alexyak/voicecontrol ]
                    alexyak
                    [card:alexyak/voicecontrol]
                      brumoeller
                      This is a really cool module. Does anyone know a good microphone that will work for the whole room? The mic I have only works when you are close.
                      • G Offline
                        gismo2006
                        @alexyak sorry, but i have a little Problem. Maybe you can help me.
                        You write on Github in your Readme file, I have to put the code (notificationReceived: function(notification, payload, sender)…) into the module to use it. I like to controll the module Simple music player by @EoF so i clone your github files copy the code into the config.js File train and download a pmdl file. But where should i paste the code notificationReceived: function(notification, payload, sender)… In the config.js File or in the mmm-music-player.js file in folder modules simple music Player?
                        Sorry i’m new in the coding world, and now a little bit confused :-D
                        Greets gismo2006
                        • 6
                        • 7
                        • 8
                        • 2 / 8
