    VoiceControl module
    79 Posts 27 Posters 125.6k Views 29 Watching
    • E
      eugekiller
      Is it possible to use this VoiceControl to hide iFrame and show iFrame
      • T
        tgl
        Hallo @GinSeng
        könntest Du mir viell. auf Deutsch weiterhelfen?
        Irgendwie will meine Musik nicht starten und mein Englisch ist nicht das beste :-(
        VG
          Jeff
          I was about to try this voice control modul to start/stop my music.
          But I can’t uploade or record files to snowboy at the moment, maybe it is partly down…
          But in the meantime I was triying to understand how to correctly install everything, but I think I’m not getting it.
          Can somebody maybe put everything in correct order.
          Where do I put the codes, what do I have to change in the mm-music-player module, where do I have to put the node_helper.js (what does it do), and so on…
          In this topic there are several questions and also answers, but I would be great to put in in order and make a summary.
          • G
            GinSeng
            @Jeff
            Lets see if i can make a complete list for you.
            Step 1. cd in your MagicMirror/module folder then git clone the modul ( https://github.com/alexyak/voicecontrol.git )
            Step 2. cd in the voice module and install dependencies ( sudo apt-get install python-pyaudio python3-pyaudio sox )
            Step 3. Create snowboy files and copy them into the ( im not sure which works i copied them in 3 placed) 1. voice control module 2. mm-music-player module and MagicMirror folder
            Step 4. cd into your mm-music-player and sudo nano mm-music-player.js add following lines after this lines:
            start: function() {
            ->> Add this
            if (notification === “PLAY”){
            var playButton = document.getElementById(‘play-button’);
            playButton.click();
            if (notification === “STOP”){
            var pauseButton = document.getElementById(‘pause-button’);
            pauseButton.click();
            then go down to
                playButton.className = "play";
                playButton.innerHTML = '<i class="fa fa-play" aria-hidden="true"></i>';
            playButton.id = ‘play-button’;
                pauseButton.className = "pause";
                pauseButton.innerHTML = '<i class="fa fa-pause" aria-hidden="true"></i>';
            pauseButton.id = ‘pause-button’;
            Then cd in your MagicMirror config and sudo nano config.js
            and add the following lines
            module: ‘voicecontrol’,
            position: ‘bottom_right’,
            models: [
            keyword: “play music”, // keyword
            description:
            file: “yourfile.pmdl”,
            message: “PLAY”,
            keyword: “stopmusic”, // keyword
            description:
            message: “STOP”
            This should be all.
            If it doesn’t work, feel free to write me a PM.
            greez GinSeng
            F J 2 Replies Last reply Reply Quote 3
            • F
              frodrd00 @GinSeng
              Hi @GinSeng ,
              How can I change the volume with the voice?
              if (notification === “VOLUME_UP”){
              if (notification === “VOLUME_DOWN”){
              Thanks.
              • G
                GinSeng
                @frodrd00 Hey sorry i didn’t try this. Maybe i find time in the Christmas vacations but exams are near so i can’t promise you :P
                  Jeff @GinSeng
                  @GinSeng said in VoiceControl module:
                  greez GinSeng
                  Thanks for the great instructions, but I think my mic isn’t working correctly :(
                  I think I have to order a new one first.
                    shashank @Jeff
                    @Jeff hi, i wanted to share my Mirror with Family for individual Email on MM, can it be possible to use voice and access individual emails, making the previous person email hide and show the other member email
                      DevilRev
                      Is there a way to set a snowboy tolerance?
                      Because even tho my command is 5 words long it gets triggered all the time when I talk normally with a friend or watch a TV show.
                        DevilRev
                        So, I found out that there is a sensitivity setting which can be changed in one of the snowboy configs permanently but it can also be controlled for each hotword individually.
                        It would be a great feature if we could set a sensitivity for each hotword in the normal config file, if you find the time i would be really thankful for this addition.
                          Medo
                          Searching for endless hours now, but no solution in sight…
                          Im trying to trigger the mm-music-player module with this voicecontrol module (i say “MUSIK ON” and the mm-music-player starts a certain mp3 file). But no luck…
                          My microfone can record audio (tested with arecord …) …
                          (note: i had to change my “sudo nano /usr/share/alsa/alsa.conf” and the entries “defaults.ctl.card 1” and “defaults.pcm.card 1” from “0” to “1” to get my USB microphone working/recording)
                          …and my mp3 soundfile can be played (tested with “omxplayer -o hdmi …”) - and also if i click on the mm-music-player-module…
                          pm2 logs mm (after a reboot) shows this:
                          [STREAMING] Now streaming realtime logs for [mm] process
                          0|mm | ALSA lib pcm_dmix.c:1022:(snd_pcm_dmix_open) unable to open slave
                          0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
                          0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
                          0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
                          0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
                          0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
                          0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
                          0|mm | ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
                          0|mm | Cannot connect to server socket err = No such file or directory
                          0|mm | Cannot connect to server request channel
                          0|mm | jack server is not running or cannot be started
                          0|mm | Expression ‘paInvalidSampleRate’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2048
                          0|mm | Expression ‘PaAlsaStreamComponent_InitialConfigure( &self->capture, inParams, self->primeBuffers, hwParamsCapture, &realSr )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2719
                          0|mm | Expression ‘PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2843
                          0|mm | Traceback (most recent call last):
                          0|mm | File “./modules/voicecontrol/snowboy/kws-multiple.py”, line 34, in
                          0|mm | detector = snowboydecoder.HotwordDetector(models, sensitivity=sensitivity)
                          0|mm | File “/home/pi/MagicMirror/modules/voicecontrol/snowboy/snowboydecoder.py”, line 115, in init
                          0|mm | stream_callback=audio_callback)
                          0|mm | File “/usr/lib/python2.7/dist-packages/pyaudio.py”, line 747, in open
                          0|mm | stream = Stream(self, *args, **kwargs)
                          0|mm | File “/usr/lib/python2.7/dist-packages/pyaudio.py”, line 442, in init
                          0|mm | self._stream = pa.open(**arguments)
                          0|mm | IOError: [Errno Invalid sample rate] -9997
                          I…
                          • installed the voicecontrol and mm-music-player
                          • double checked the code
                          • changed the mp3 file with another
                          • implemented the code like “GinSeng” stated some lines above.
                          • created the hotwords over at snowboy and copied them to “/MagicMirror”, “voicecontrol” and “mm-music-player” directories
                            But im not able to find the problem…
                          Any suggestions?
                          Thanks a lot for your help…
                          • T
                            thereisnotry87
                            Hello guys, it seems I have the same problem as @frodrd00 and @Medo and cannot properly run the voicecontrol module. In my case I want to use the camera module which works together with the mentioned one. I’ve checked the voicemodule.js to match with its corresponding declaration in config.js and everything looks fine.
                            **config.js**
                                	module: 'voicecontrol',
                                	position: 'bottom_left',
                                    	models: [
                                            	keyword: "Show Camera",
                                            	description: "Say 'Show Camera' to display camera",
                                            	file: "ShowCamera.pmdl",
                                            	message: "SHOW_CAMERA"
                                            	keyword: "Hide Camera",
                                            	description: "Say 'Hide Camera' to hide camera",
                                            	file: "HideCamera.pmdl",
                                            	message: "HIDE_CAMERA"
                                            	keyword: "Selfie",
                                            	description: "Say 'Selfie' when camera is visible",
                                            	file: "Selfie.pmdl",
                                            	message: "SELFIE"
                            voicecontrol.js
                            models: [
                            		keyword: "Selfie",
                            		message: "SELFIE"
                            How did you manage this problem?
                            Thanks a lot in advance ))
                              shashank @thereisnotry87
                              @thereisnotry87 hi, no need to mention voicecontrol commands in config.js file, just mention only as below , make sure you have installed
                              and
                              copy all pmdl files in MM root folder
                              	    position: 'top_left',
                              go to /usr/share/alsa/alsa.conf and change 0 to 1 in below parameters
                              defaults.ctl.card 1
                              defaults.pcm.card 1,
                              this worked for me.
                                shramik49
                                hi,
                                i am having difficulty in adding voicecontrol module on my magic mirror.
                                i want to use voicecontrol to use camera.
                                so can someone help me with the steps to follow?
                                  pepemujica
                                  Hi! is it possible with this module to hide/show different modules or even switch profile with profile switcher?
                                  Kind regards
                                    disakos
                                    Hello Guys , @alexyak .
                                    I;m running this module and hot word detection is working ok, i used my own keyword and send notfication to other modules. I can see in console.log .
                                    MMM-temp-ds18b20 received a module notification: LUSTRO from sender: voicecontrol
                                    In all my modules. but i’m unable to run for example script … I tried to modify node_helper.js
                                    /* Magic Mirror
                                     * Module: voicecontrol
                                     * By Alex Yaknin
                                     * MIT Licensed.
                                    const NodeHelper = require('node_helper');
                                    const exec = require('child_process').exec;
                                        start: function () {
                                            this.started = false;
                                                    if (notification === "CONNECT") {
                                                            this.startRecognition(payload);
                                                            return;
                                                    if (notification === "LUSTRO"’) {
                                                            exec("/opt/vc/bin/tvservice -o", null);
                                                    //      this.autosleep();
                                    but it is not working … ;)
                                    • romainR
                                      romain
                                      Hello everybody, I try to use this voicecontrol module AND mmm-alexa in the same time (mmm-alexa need to be trigger by a notification. That where voicecontrol is interesting at the moment) but because both the module use the mic, it doesn’t work.
                                      If I put only one module at the time no problem. Both of them in the same time, voice control doesn’t work.
                                      How can I use the same mic for two different module ?
                                        disakos
                                        @romain , do you use voicecontrol module to run some scripts ? If so please let me know how to do it … ;) my module is detecting my voice … but i’m unable to run something … ;)
                                        romainR 1 Reply Last reply Reply Quote 0
                                        • romainR
                                          romain @disakos
                                          @disakos I didn’t use it to run script, I wanted it specificaly for mmm-alexa. However I did check that the other module received the notification It send.
                                          I did that by writing my own useless module that only print the notification it received.
                                          You need in your main file a
                                          notificationReceived: function(notification, payload, sender){
                                             //Whatever you want to do
                                          This is different to “socketNotificationReceived” , socket notification receive only deal with your node helper file. But “notificationReceived” catch notification send from a module to another.
                                          With that in mind, you can add the notificationReceived thing to the module you want to control with the voicecontrol module or add whatever you need to it if it already exist
                                          • romainR
                                            romain
                                            I did it, It wasn’t easy but it’s work, I can use voicecontrol and others voicecontrol driven module at the same time.
                                            I had to change my /etc/asound.conf file again (yes, again. Because changing it already solve some of my issue on the past)
                                            before my file looked like this:
                                            pcm.!default {
                                                    type asym
                                                    playback.pcm {
                                                            type plug
                                                            slave.pcm "hw:0,0"
                                                    capture.pcm {
                                                            type plug
                                                            slave.pcm "hw:1,0"
                                            Easy enough when you know what your doing (that wasn’t my case). this file is there to say what is the default device to playback and capture (A lot of application or software just use the default device so if the default configuration isn’t working for you, you need to change it for you.) In my cas ethe microphone is the “hw:1,0” and my speaker is the “hw:0,0”
                                            That worked well when my microphone is used by one application at the time. However, not so much when it need to be used by multiple ones.
                                            So my new /etc/asound.conf file is looking like this now
                                            pcm.myTest {
                                                type dsnoop
                                                ipc_key 2241234
                                                slave {
                                                    pcm "hw:1,0"
                                                    channels 1
                                            pcm.!default {
                                                    type asym
                                                    playback.pcm {
                                                            type plug
                                                            slave.pcm "hw:0,0"
                                                    capture.pcm {
                                                            type plug
                                                            slave.pcm "myTest"
                                            instead of directly say that my input device is the “hw:1,0” I say it’s “myTest”, which is describe above. myTest’s type is “dsnoop” , that’s whats allow the michrophone to be use by multiple application at the same time. The ipc_key is there with a random value because when I tested with arecord, it asked me to put one. The channels is there because it was on the documentation ( http://alsa.opensrc.org/Dsnoop ) >.> not sure what it does though.
                                            And there you go, after that I could use two voice control things at the time
                                            • 3 / 4
