    VoiceControl module
    79 Posts 27 Posters 125.6k Views 29 Watching
    • G
      GinSeng
      @frodrd00 Hey sorry i didn’t try this. Maybe i find time in the Christmas vacations but exams are near so i can’t promise you :P
        Jeff @GinSeng
        @GinSeng said in VoiceControl module:
        greez GinSeng
        Thanks for the great instructions, but I think my mic isn’t working correctly :(
        I think I have to order a new one first.
          shashank @Jeff
          @Jeff hi, i wanted to share my Mirror with Family for individual Email on MM, can it be possible to use voice and access individual emails, making the previous person email hide and show the other member email
            DevilRev
            Is there a way to set a snowboy tolerance?
            Because even tho my command is 5 words long it gets triggered all the time when I talk normally with a friend or watch a TV show.
              DevilRev
              So, I found out that there is a sensitivity setting which can be changed in one of the snowboy configs permanently but it can also be controlled for each hotword individually.
              It would be a great feature if we could set a sensitivity for each hotword in the normal config file, if you find the time i would be really thankful for this addition.
                Medo
                Searching for endless hours now, but no solution in sight…
                Im trying to trigger the mm-music-player module with this voicecontrol module (i say “MUSIK ON” and the mm-music-player starts a certain mp3 file). But no luck…
                My microfone can record audio (tested with arecord …) …
                (note: i had to change my “sudo nano /usr/share/alsa/alsa.conf” and the entries “defaults.ctl.card 1” and “defaults.pcm.card 1” from “0” to “1” to get my USB microphone working/recording)
                …and my mp3 soundfile can be played (tested with “omxplayer -o hdmi …”) - and also if i click on the mm-music-player-module…
                pm2 logs mm (after a reboot) shows this:
                [STREAMING] Now streaming realtime logs for [mm] process
                0|mm | ALSA lib pcm_dmix.c:1022:(snd_pcm_dmix_open) unable to open slave
                0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
                0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
                0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
                0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
                0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
                0|mm | ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
                0|mm | ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
                0|mm | Cannot connect to server socket err = No such file or directory
                0|mm | Cannot connect to server request channel
                0|mm | jack server is not running or cannot be started
                0|mm | Expression ‘paInvalidSampleRate’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2048
                0|mm | Expression ‘PaAlsaStreamComponent_InitialConfigure( &self->capture, inParams, self->primeBuffers, hwParamsCapture, &realSr )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2719
                0|mm | Expression ‘PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2843
                0|mm | Traceback (most recent call last):
                0|mm | File “./modules/voicecontrol/snowboy/kws-multiple.py”, line 34, in
                0|mm | detector = snowboydecoder.HotwordDetector(models, sensitivity=sensitivity)
                0|mm | File “/home/pi/MagicMirror/modules/voicecontrol/snowboy/snowboydecoder.py”, line 115, in init
                0|mm | stream_callback=audio_callback)
                0|mm | File “/usr/lib/python2.7/dist-packages/pyaudio.py”, line 747, in open
                0|mm | stream = Stream(self, *args, **kwargs)
                0|mm | File “/usr/lib/python2.7/dist-packages/pyaudio.py”, line 442, in init
                0|mm | self._stream = pa.open(**arguments)
                0|mm | IOError: [Errno Invalid sample rate] -9997
                I…
                • installed the voicecontrol and mm-music-player
                • double checked the code
                • changed the mp3 file with another
                • implemented the code like “GinSeng” stated some lines above.
                • created the hotwords over at snowboy and copied them to “/MagicMirror”, “voicecontrol” and “mm-music-player” directories
                  But im not able to find the problem…
                Any suggestions?
                Thanks a lot for your help…
                • T
                  thereisnotry87
                  Hello guys, it seems I have the same problem as @frodrd00 and @Medo and cannot properly run the voicecontrol module. In my case I want to use the camera module which works together with the mentioned one. I’ve checked the voicemodule.js to match with its corresponding declaration in config.js and everything looks fine.
                  **config.js**
                      	module: 'voicecontrol',
                      	position: 'bottom_left',
                          	models: [
                                  	keyword: "Show Camera",
                                  	description: "Say 'Show Camera' to display camera",
                                  	file: "ShowCamera.pmdl",
                                  	message: "SHOW_CAMERA"
                                  	keyword: "Hide Camera",
                                  	description: "Say 'Hide Camera' to hide camera",
                                  	file: "HideCamera.pmdl",
                                  	message: "HIDE_CAMERA"
                                  	keyword: "Selfie",
                                  	description: "Say 'Selfie' when camera is visible",
                                  	file: "Selfie.pmdl",
                                  	message: "SELFIE"
                  voicecontrol.js
                  models: [
                  		keyword: "Selfie",
                  		message: "SELFIE"
                  How did you manage this problem?
                  Thanks a lot in advance ))
                    shashank @thereisnotry87
                    @thereisnotry87 hi, no need to mention voicecontrol commands in config.js file, just mention only as below , make sure you have installed
                    sudo apt-get install python-pyaudio python3-pyaudio sox
                    and
                    copy all pmdl files in MM root folder
                    	    position: 'top_left',
                    go to /usr/share/alsa/alsa.conf and change 0 to 1 in below parameters
                    defaults.ctl.card 1
                    defaults.pcm.card 1,
                    this worked for me.
                      shramik49
                      hi,
                      i am having difficulty in adding voicecontrol module on my magic mirror.
                      i want to use voicecontrol to use camera.
                      so can someone help me with the steps to follow?
                        pepemujica
                        Hi! is it possible with this module to hide/show different modules or even switch profile with profile switcher?
                        Kind regards
                          disakos
                          Hello Guys , @alexyak .
                          I;m running this module and hot word detection is working ok, i used my own keyword and send notfication to other modules. I can see in console.log .
                          MMM-temp-ds18b20 received a module notification: LUSTRO from sender: voicecontrol
                          In all my modules. but i’m unable to run for example script … I tried to modify node_helper.js
                          /* Magic Mirror
                           * Module: voicecontrol
                           * By Alex Yaknin
                           * MIT Licensed.
                          const NodeHelper = require('node_helper');
                          const exec = require('child_process').exec;
                              start: function () {
                                  this.started = false;
                                          if (notification === "CONNECT") {
                                                  this.startRecognition(payload);
                                                  return;
                                          if (notification === "LUSTRO"’) {
                                                  exec("/opt/vc/bin/tvservice -o", null);
                                          //      this.autosleep();
                          but it is not working … ;)
                          • romainR
                            romain
                            Hello everybody, I try to use this voicecontrol module AND mmm-alexa in the same time (mmm-alexa need to be trigger by a notification. That where voicecontrol is interesting at the moment) but because both the module use the mic, it doesn’t work.
                            If I put only one module at the time no problem. Both of them in the same time, voice control doesn’t work.
                            How can I use the same mic for two different module ?
                              disakos
                              @romain , do you use voicecontrol module to run some scripts ? If so please let me know how to do it … ;) my module is detecting my voice … but i’m unable to run something … ;)
                              romainR 1 Reply Last reply Reply Quote 0
                              • romainR
                                romain @disakos
                                @disakos I didn’t use it to run script, I wanted it specificaly for mmm-alexa. However I did check that the other module received the notification It send.
                                I did that by writing my own useless module that only print the notification it received.
                                You need in your main file a
                                notificationReceived: function(notification, payload, sender){
                                   //Whatever you want to do
                                This is different to “socketNotificationReceived” , socket notification receive only deal with your node helper file. But “notificationReceived” catch notification send from a module to another.
                                With that in mind, you can add the notificationReceived thing to the module you want to control with the voicecontrol module or add whatever you need to it if it already exist
                                • romainR
                                  romain
                                  I did it, It wasn’t easy but it’s work, I can use voicecontrol and others voicecontrol driven module at the same time.
                                  I had to change my /etc/asound.conf file again (yes, again. Because changing it already solve some of my issue on the past)
                                  before my file looked like this:
                                  pcm.!default {
                                          type asym
                                          playback.pcm {
                                                  type plug
                                                  slave.pcm "hw:0,0"
                                          capture.pcm {
                                                  type plug
                                                  slave.pcm "hw:1,0"
                                  Easy enough when you know what your doing (that wasn’t my case). this file is there to say what is the default device to playback and capture (A lot of application or software just use the default device so if the default configuration isn’t working for you, you need to change it for you.) In my cas ethe microphone is the “hw:1,0” and my speaker is the “hw:0,0”
                                  That worked well when my microphone is used by one application at the time. However, not so much when it need to be used by multiple ones.
                                  So my new /etc/asound.conf file is looking like this now
                                  pcm.myTest {
                                      type dsnoop
                                      ipc_key 2241234
                                      slave {
                                          pcm "hw:1,0"
                                          channels 1
                                  pcm.!default {
                                          type asym
                                          playback.pcm {
                                                  type plug
                                                  slave.pcm "hw:0,0"
                                          capture.pcm {
                                                  type plug
                                                  slave.pcm "myTest"
                                  instead of directly say that my input device is the “hw:1,0” I say it’s “myTest”, which is describe above. myTest’s type is “dsnoop” , that’s whats allow the michrophone to be use by multiple application at the same time. The ipc_key is there with a random value because when I tested with arecord, it asked me to put one. The channels is there because it was on the documentation ( http://alsa.opensrc.org/Dsnoop ) >.> not sure what it does though.
                                  And there you go, after that I could use two voice control things at the time
                                    Rattenjunge8080
                                    I’m new here, and I need a little bit help…
                                    I still don’t get the concept of this module for 100%, but I will describe my problem as accurate as possible.
                                    So I downloaded the module and installed python-pyaudio. I created a PMDL-File (here: http://filehorst.de/d/bDfbfCBE), tested it and saved it in the MagicMirror-Location (and many other locations…). I recorded it on the Pi btw, microphone is also still working.
                                    I don’t know if I miss anything, but when I start the MM, the modules are totally fine, I keep saying my command (“Go to sleep”), but nothing happens. I also checked the dev-mode and set breakpoints…but like I said, I’m not 100% sure what every class is doing in particular. Here is my code, do I miss anything?
                                    config.js
                                    			module: "helloworld1",
                                    			position: "bottom_right",	// This can be any of the regions.
                                    				text: "Hello world!"
                                                    models: [
                                                            keyword: "gotosleep",   // keyword
                                                            file: "GoToSleep.pmdl", // trained model file name
                                                            message: "gotosleep"   // notification message that's broadcast in the MagicMirror app
                                                            keyword: "wake up",   // keyword
                                                            file: "Wake_up.pmdl", // trained model file name
                                                            message: "wake_up"   // notification message that's broadcast in the MagicMirror app
                                    Voicecontrol.js
                                    'use strict';
                                    Module.register("voicecontrol", {
                                    	// Default module config.
                                        defaults: {
                                    		models: [
                                    						description: "Go To Sleep",
                                    						file: "hideCamera.pmdl",
                                    						keyword: "Selfie",
                                    						file: "selfie.pmdl",
                                    						message: "SELFIE"
                                        start: function() {
                                            this.sendSocketNotification("CONNECT", this.config);
                                        getStyles: function() {
                                    		return ['voicecontrol.css'];
                                        socketNotificationReceived: function(notification, payload){
                                            if (notification === "KEYWORD_SPOTTED"){
                                                //Broadcast the message
                                                this.sendNotification(payload.message, {type: "notification"});
                                        getDom: function() {
                                            var header = document.createElement("header");
                                            header.innerHTML = "Voice Commands";
                                            wrapper.appendChild(header);
                                            var models = this.config.models;
                                            models.forEach(function(model) {
                                                var command = document.createElement("div");
                                                command.innerHTML = model.description;
                                                command.className = "small dimmed top";
                                                wrapper.appendChild(command);
                                            }, this);
                                            return wrapper;
                                    helloworld1.js (I wanted to log the notification to see if it works…)
                                    Module.register("helloworld1",{
                                    	defaults: {
                                    		text: "World!"
                                    	start: function() {
                                    		Log.log("Starting module: " + this.name);
                                    		if (notification === "gotosleep"){
                                    			Log.log("Go To Sleep");
                                    	// Override dom generator.
                                    		wrapper.innerHTML = this.config.text;
                                    		return wrapper;
                                    • romainR
                                      romain
                                      The code look’s fine to me at first glance. (You don’t need to have the { keyword: "gotosleep", // keyword description: "Go To Sleep", file: "GoToSleep.pmdl", // trained model file name message: "gotosleep" // notification message that's broadcast in the MagicMirror app }, in both config file and the voice controle.js at the same time though. But that’s not an issue.)
                                      Maybe try to add a position for the voicecontrol module just to be sure the module itself doesn’t crash (If you add a position it should print the description of the words on screen. If nothing appear it probably mean something went wrong.)
                                      If nothing wrong and the cd ~/MagicMirror/ ; DISPLAY=:0 npm start dev didnt show an error, maybe the issue is with your mic configuration. If the module dosn’t hear you it might not work.
                                      Add a Log.log("Helloworld1 received " + notification); before the if in the helloword1.js . SO you print every single notification you receive and maybe add a Log in the socketNotificationReceive of voicecontrol.js to see if it spot your keywords at all.
                                      also, do you use your microphone with this module only or with multiple application ? Because by default, I think, a microphone can only be open by one thing at the time. So try toclose every application that use your microphone and run the mirror. If the that’s work you might to configure your microphone so it can be open in multiple application
                                        claudia
                                        im trying to get the module to work on my Magic Mirror but without any luck so far. I have a google maps API that opens in an iframe (iFrame reload module) which i currently have to click on my Magic Mirror to display. I am trying to instead have it open using voice control rather than clicking on it. Any ideas on how to get this to work?
                                        • romainR
                                          romain @claudia
                                          @claudia first thing first. Did you made a snowboy word ? then did you put the file in your MagicMirror folder ? Then did you put it in your configuration (you should probably delete their example since they didn’t provide the file to go with it. inside the config from the voicecontrol.js too).
                                          Then when you say the word, is the module picking it up and send the associate notification ?
                                          You can know if the notification is sended by runing the mirror in dev mode so you can see the console and use some module to print the notification they receive (I think some default module do it already).
                                          When you got this part to work, you can proceed to the next step, which is catch the notification in the Iframe module
                                            claudia @romain
                                            @romain thanks for getting back to me. I have made a snowboy word (showmap.pmdl) , as well as adding it into the magic mirror folder, and changing the config.js file and the voice control.js file accordingly.
                                            To see if the module is picking up the word, how would you run the mirror in dev mode? I’m not sure how to do this.
                                            Thanks again.
                                            • 4 / 4
