    PIR-Sensor detecting motion even when there's no movement
    2 Posts 2 Posters 2.1k Views 1 Watching
    • MitchfarinoM
      Mitchfarino Module Developer
      Hi All
      I’ve just hooked up my PIR sensor to my Pi3
      I ran a variant of this, and it was constantly detecting movement even when I was covering it up, so nothing should have been detected.
      Is there an issue with my sensor? Or is that standard? Or can I turn down the sensitivity in some way?
      import RPi.GPIO as GPIO
      import time
      GPIO.setwarnings(False)
      GPIO.setmode(GPIO.BOARD)
      GPIO.setup(3,GPIO.OUT)     #Define pin 3 as an output pin
      while True:
              GPIO.output(3,1)   #Outputs digital HIGH signal (5V) on pin 3
              time.sleep(1)      #Time delay of 1 second
              GPIO.output(3,0)   #Outputs digital LOW signal (0V) on pin 3
      Edit from admin: Please use Markdown on code snippets!
      • KirAsh4K
        KirAsh4 Moderator
        I don’t have a PIR sensor to fiddle with … however, why are you setting pin 3 HIGH, and as an OUTPUT? If it’s to power the PIR sensor board, don’t, use either pin 1 or 17, those have a constant 3v3 on them (or if you know your sensor can tolerate 5V, use pins 2 or 4). If it’s to read from the PIR sensor, it needs to be set as an INPUT pin so it can detect when the sensor triggers it.
