    MMM-MyScoreboard
    Scheduled Pinned Locked Moved Sport
    277 Posts 60 Posters 635.7k Views 63 Watching
      1a2a3a @sdetweil
      weak? absolute?
        sdetweil @1a2a3a
        @1a2a3a
          <div class="MMM-MyScoreboard">
             <div class="box-score">
                   <div class="stackedWithLogos home-team-first">
                         <div >some text </div>
             <div class="box-score stackedWithLogos home-team-first>hit the jackpot</div>
         </div>
        because your second part of the selector clause has no spaces,
        ALL THREE classes MUST appear in the class= of the element (absolute AND)
        so the element with ‘some text’ will NOT be selectable
        but element WITH all three, hit the jackpot, WILL BE selectable
        (selectable depending on the next 2 classes, which I didn’t show)
        S 1 2 Replies Last reply Reply Quote 0
          SirFM @sdetweil
          I haven’t dove into the code but do you know if the W-L record of the teams could easily be displayed?
            1a2a3a @sdetweil
            @sdetweil I can’t Sam, I really can’t. Spent 3 days trying to get this and cron job for schedule on off on Wayland. Managed to get cron to work finally, but no dice on this.
              sdetweil @1a2a3a
              @1a2a3a i understand… open the developers window on the MM browser (best to use the PC browser)
              ctrl-shift-i
              select the elements tab
              select the pointer in the top left of the elements tab
              move the mouse pointer over the MM web page contents to you get to the MMM-MyScoreboard module, all the content should be highlighted
              click mouse
              in the developers window, the (selected by click) module content will be shown
              with all the classes and explicit attributes attached…
              see this topic with screen shots to help see my post here
              https://forum.magicmirror.builders/post/90135
                1a2a3a
                anyone having issue with the module? its not showing anything now despite games being on.
                getting something like this in the dev mode
                M-MyScoreboard] Updating Scores
                module.js:367 Parameter mismatch in module.hide: callback is not an optional parameter!
                main.js:671 module tries to update the DOM without being displayed.
                • C
                  crcowan
                  It appears that the SportsNet feed is not updating during the day. It shows a scores of zero all day.
                  • D
                    Dysantic @crcowan
                    @crcowan
                    Sportsnet made a change to the hostname for the API, yet their old hostname (and the one this module uses) still has access to the “pre-game” data, which is why we still see the game time, but no live updates or post-game scores.
                    A quick fix is to go into the “SNET.js” file, and look for:
                    var url = "https://mobile-statsv2.sportsnet.ca/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                    Update the hostname from “mobile-statsv2.sportsnet.ca” to “stats-api.sportsnet.ca” like so:
                    var url = "https://stats-api.sportsnet.ca/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                    The API output is still formatted as the module expects, and all should work again.
                    I’ve submitted a pull request, and hopefully I did this correctly… it’s my first time submitting an update via GitHub:
                    https://github.com/jclarke0000/MMM-MyScoreboard/pull/91
                    W blake_northrupB 2 Replies Last reply Reply Quote 1
                    • W
                      wyovino @Dysantic
                      I’d like to increase the size of the start time for an upcoming game. Which element in the CSS file would that be?
                        sdetweil @wyovino
                        @wyovino I do not know
                        you can look at the css provided by the module in the module folder. it may give you info about that content style
                        you can also use the developer window to examine and change styles to determine how to set custom.css
                        see this post
                        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues/2?_=1720443608424
                        W 1 Reply Last reply Reply Quote 1
                        • E
                          ericsprime18
                          This post is deleted!
                          • W
                            wyovino @sdetweil
                            For anyone else interested, I changed the following in the MMM-MyScoreboard.css file:
                            In the "MMM-MyScoreboard .box-score .status " section
                            font-size: 20px;
                            font-weight: 400;
                            To:
                            font-sze: 30px;
                            font-weight: bold;l
                            • blake_northrupB
                              blake_northrup @Dysantic
                              @Dysantic Thank you for this fix @Dysantic! Works like a charm!
                              • O
                                ogunn
                                @blake_northrup can you post your config code for your scoreboard because I still can’t get it to load. Thanks,
                                • D
                                  dathbe @ogunn
                                  FYI, i have taken over maintaining this module and have made some updates. anyone interested can check out at https://github.com/dathbe/MMM-MyScoreboard .
                                  open an issue if you have problems or a suggestion.
                                  BKeyportB 1 Reply Last reply Reply Quote 1
                                  • BKeyportB
                                    BKeyport Module Developer @dathbe
                                    @dathbe Thank you. I’ve wanted to install this module again, but I have worries about longevity.
                                    • D
                                      dathbe @BKeyport
                                      @BKeyport Awesome. Unrelated, but I love your MMM-Multimonth.
                                      • 10
                                      • 11
                                      • 12
                                      • 13
                                      • 14
                                      • 14 / 14
