    CalDAV
    26 Posts 8 Posters 22.3k Views 8 Watching
    • P Offline
      poekel
      Beh,
      I think i have got the right syntax to retrieve the ics files from baikal.
      Can you explain how you did it on the mirror?
      • P Offline
        poekel
        @beh
        I have read your workaround…
        I am using Baikal on my synology.
        i do NOT have this > https://dav.example.org/dav.php/calendars/[username]/Events?export folder
        http://192.168.1.xx/baikal/html/dav.php/calendars/xxxx/calendar-name?export&startdate=1488672000 (=example)
        How do i get the record from Baikal in 1 file given a certain start-end date in a file from the command line.
        If that works i can change the url in the MM2 config.js file and point to that created file
        Please help …
        BehB 1 Reply Last reply Reply Quote 0
        • BehB Offline
          Beh @poekel
          Hey @poekel
          you have to use the keyword start instead of startdate.
          It’s described in the sabre/dav documentation here: http://sabre.io/dav/ics-export-plugin/
          So your request should look like this:
          http://192.168.1.xx/baikal/html/dav.php/calendars/xxxx/calendar-name?export&start=1488672000
          You can use this URL in your MM2 config file. It returns a valid .ics file. I’m using this on my mirror too.
          And please note, that your calendar-name must be the internal name in Baikal (you can look this name up in the admin settings when you edit a calendar)
          • P Offline
            poekel @Beh
            @Beh
            Thanx for the link!.
            It works, it creates a file with nothing more than this:
            BEGIN:VCALENDAR
            VERSION:2.0
            CALSCALE:GREGORIAN
            PRODID:-//SabreDAV//SabreDAV 3.1.3//EN
            X-WR-CALNAME:XXXXXXXXXXXX
            X-APPLE-CALENDAR-COLOR:#FF2968
            END:VCALENDAR
            164 bytes
            How do you handle the username and password that goes with the calendar in baikal?
            Does the link in the config.js not ask for a username and password for the baikal calendar ?
            • BehB Offline
              Beh @poekel
              @poekel
              I will try a request with a start parameter when I’m home and test if it works with my Baikal server.
              For user credentials:
              Just add user and pass to your calendar config like this:
              		url: 'http://192.168.1.xx/baikal/html/dav.php/calendars/xxxx/calendar-name?export&start=1488672000',
              		symbol: 'calendar',
              		user: 'USERNAME',
              		pass: 'PASSWORD'
              Additionally, Baikal uses Digest authentication. To use this, you have to change the sendImmediately option in the calendarfetcher.js to false. (As I already described above)
              The option is located here. The file is located in MagicMirror/modules/default/calendar/calendarfetcher.js
              In a future version of MM2, there will be an option for this directly in the config file so you don’t have to change this in calendarfetcher.js. I already submitted a pull request for that.
              • BehB Offline
                Beh
                Hey, @poekel
                after some trying on my Baikal server, I found out, that just the use of the start parameter alone is not working indeed.
                However, I was able to get a request, if you add the componentType option to the request URL. You have to filter the type to VEVENT. But thats no problem, because the documentation says, that this is the only working type for export anyway.
                So I got valid answers with the following URL scheme (including recognized timestamp):
                https://dav.example.com/dav.php/calendars/USERNAME/calendarname?export&start=1490745600&componentType=VEVENT
                • P Offline
                  poekel
                  Your the Greatest!
                  Man , it works ! Unbelievable ! Many thanks!!!
                  • O Offline
                    OsCourt
                    Hi gentlemen,
                    I’m sorry to reopen this old topic.
                    What you are succeeded to do here it’s exactly what I search to do but it doesn’t work on my MagicMirror.
                    • I have a Syno with Baikal (http://ipaddress/baikal/admin)
                    • I have a user (homemagic) with his calendar (default)
                    • My calendarfetcher.js is up-to-date (v2.2.0)
                    URL I use for :
                    http://ipaddress/baikal/cal.php/calendars/homemagic/default?export&start= 1514761200&componentType=VEVENT
                    • Work on my android mobile with Caldav Sync Free Beta (PlayStore)
                    • Work on ThunderBird
                    • Doesn’t work on my MagicMirror :'(
                    • My web browser (IE) return an error when I try to export
                    Someone could help me please :)
                    • BehB Offline
                      Beh @OsCourt
                      @OsCourt I think you need to use dav.php instead of cal.php on newer baikal versions. Also you need to use digest authentication with the calendar module of the mirror. It’s described in the readme of the module.
                      • O Offline
                        OsCourt
                        Thanks @Beh.
                        I don’t have dav.php file in my baikal folder on my Syno :/
                        I had already read the readme and I have the digest authentication in the mirror:
        symbol: "calendar-check-o ",
        url: 'http://ipaddress/baikal/cal.php/calendars/homemagic/default?export&start=1514761200&componentType=VEVENT',
        auth: {
        user: "homemagic",
        password: "pass",
        method: "digest"
                        • 2 / 3
