    Trafficmaps
    63 Posts 11 Posters 75.1k Views 12 Watching
    • W Offline
      wscheer
      Hey All,
      I’ve been tinkering around with the Bing Traffic maps a little more. I made it a bit more customizable but I’m having an issue where the map never refreshes.
      I’ve tried calling updateDom() but that does not seem to do anything. I also tried setting the wrapper to ’ ’ before it is set to the bing url path.
      Any ideas?
      Module.register("maproute", {
              defaults: {
                      latitude: '40.4406', // city latitude
                      longitude: '-79.9959', // city longitude
                      map_zoom: '12', // 1 - 21
                      map_layer: 'TrafficFlow',
                      map_size: '500', // using this for both length and width
                      api_key: '1234567890', //  your bing maps api key
                      updateInterval: 300000 // 5 mins
              getDom: function() {
                      var wrapper = ''; // tried setting this to blank to see if that would clear out the old image
                      wrapper = document.createElement("img");
                      // create the url using the custom parameters
                      wrapper.src = "http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/" + this.config.latitude + "," + this.config.longitude + "/" + this.config.map_zoom + "?mapSize=" + this.config.map_size + "," + this.config.map_size + "&ml=" + this.config.map_layer + "&key=" + this.config.map_key;
                      return wrapper;
      	start: function() {
      		var self = this;
      		setInterval(function() {
      			self.updateDom(); // no speed defined, so it updates instantly.
      		}, this.config.updateInterval);
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @wscheer
        @wscheer Quote from the readme Whenever your module need to be updated, call the updateDom(speed) method. It requests the MagicMirror core to update it's dom object. If you define the speed, the content update will be animated, but only if the content will realy change. So i guess your html looks all the time the same, so there is probably no real update of the dom. I suggest to try to add an timestamp somewhere and see if it gets updated then
        • W Offline
          wscheer
          @strawberry-3-141 Ding! Ding! Ding! That was it! THANK YOU!
          Also thanks again to @alexyak and @tyho for their input.
          I’ll post the code for anyone who wants Bing Traffic maps on their Magic Mirror.
          It’s a little hackish but maybe someone will come along and write it the correct way. Basically I’m taking the pushpin (pp) parameter and just assigning two random numbers to it. Math.random() creates a number between 0 and 1. So the map never shows the pushpin on the area I’m at. This causes the information to be “new” so when updateDom() is called, the info has changed.
          For any beginners, here is my file structure setup:
          The code below is located: /var/www/html/MagicMirror/modules/maproute/maproute.js
                  defaults: {
                          latitude: '40.4406', // City latitude. Use google to get these coordinates
                          longitude: '-79.9959', // City longitude
                          map_size: '500', // Using this for both length and width
                          api_key: '123456789', // Your Bing maps api key
                          updateInterval: 300000 // 5 min refresh
                          var wrapper = '';
                          // The Math.random() calls are to place a random pushpin on the map and make the updateDom() call refresh
                          wrapper.src = "http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/" + this.config.latitude + "," + this.config.longitude + "/" + this.config.map_zoom + "?mapSize=" + this.config.map_size + "," + this.config.map_size + "&pp=" + Math.random() + "," + Math.random() + "&ml=" + this.config.map_layer + "&key=" + this.config.map_key;
                          return wrapper;
          	start: function() {
          		var self = this;
          			self.updateDom(5000); // I set a 5 second refresh here for testing.
          J Z 2 Replies Last reply Reply Quote 1
            Jeff @wscheer
            @wscheer
            Is this modul still working?
            I did everthing you explained:
            in my config.js:
                                  module: 'maproute',
                                  position: 'middle_center',
            And /var/www/html/MagicMirror/modules/maproute/maproute.js is the code from above.
            I’ve created an API for Bing maps.
            But if I run MM I just see a small image. Like the right picture could not be found.
            And if I look to the report om bing how often my API was used, it counts 0.
            Where is the mistake?
            • W Offline
              wscheer @Jeff
              @Jeff yeah mine is still working.
              To troubleshoot you could run magic mirror in “standalone” mode. That would let you view the page on a desktop computer and you can look at the browser console to see what the errors are.
              Let me know if you need more instructions on that. I’m on a mobile right now. I could add more later.
                Jeff @wscheer
                @wscheer
                Thanks for your quick reply.
                Can you just tell me how to enter the “standalone” mode?
                thanks
                • W Offline
                  wscheer @Jeff
                  @Jeff yeah
                  execute the following command from the MagicMirror folder: “node serveronly”. This will start the server, after which you can open the application in your browser of choice.
                    Jeff @wscheer
                    @wscheer
                    oh okay, I already did that and the command line said my page was created correctly.
                    But in teh browser it said page not found.
                    I think that’s a different problem and I have to handle that first…
                      Jeff
                      Now I can open the MM in the webbrowser.
                      What should I do now?
                      • W Offline
                        wscheer @Jeff
                        @Jeff Ok so now if you load the page and you still see the broken image, the browser can help you find out what the problem is.
                        If you use firefox, hit F12 and reload the magic mirror page you can see if there are any errors being reported. When I was first testing mine, I had an typo in the api string and I couldn’t really see it until I looked at it in the browser.
                        Let me know if that helps, or post some screenshots of any errors and hopefully I can help :)
                        • 6
                        • 7
                        • 5 / 7
