    Trafficmaps
    63 Posts 11 Posters 77.5k Views 12 Watching
      Jeff @wscheer
      @wscheer
      I’ve installed Firefox:
      Initializing MagicMirror.  logger.js:17:4
      Loading core translation file: translations/de.json  logger.js:20:4
      Loading core translation fallback file: translations/en.json  logger.js:20:4
      Load script: modules/default/alert//alert.js  logger.js:20:4
      Module registered: alert  logger.js:20:4
      Bootstrapping module: alert  logger.js:17:4
      Load script: modules/default/alert//classie.js  logger.js:20:4
      Load script: modules/default/alert//modernizr.custom.js  logger.js:20:4
      Load script: modules/default/alert//notificationFx.js  logger.js:20:4
      Scripts loaded for: alert  logger.js:20:4
      Load stylesheet: modules/default/alert//ns-default.css  logger.js:20:4
      Styles loaded for: alert  logger.js:20:4
      alert - Load translation: translations/de.json  logger.js:20:4
      alert - Load translation fallback: translations/en.json  logger.js:20:4
      Translations loaded for: alert  logger.js:20:4
      Load script: modules/maproute//maproute.js  logger.js:20:4
      Module registered: maproute  logger.js:20:4
      Bootstrapping module: maproute  logger.js:17:4
      Scripts loaded for: maproute  logger.js:20:4
      Styles loaded for: maproute  logger.js:20:4
      Translations loaded for: maproute  logger.js:20:4
      Load stylesheet: css/custom.css  logger.js:20:4
      Starting module: alert  logger.js:17:4
      All modules started!  logger.js:17:4
      maproute received a system notification: ALL_MODULES_STARTED  logger.js:20:4
      maproute received a system notification: DOM_OBJECTS_CREATED  logger.js:20:4
      GET
      http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/40.4406,-79.9959/12 [HTTP/1.1 401 Unauthorized 108ms]
      I think I have a wrong API access, but I think I did everything as described…
      • W Offline
        wscheer @Jeff
        @Jeff Ok now we are getting somewhere.
        Try this:
        In your browser, paste this url but add your bing maps api key at the end. Mine looks like this (i replaced some characters with #)
        ######ss9ZpK9lZjPRNo78Xp######xM_zjDmyQ2M5GmkzcOUhW2BYmO######-2
        http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/40.4406,-79.9959/12?mapSize=500,500&ml=TrafficFlow&key= ADD YOUR API KEY HERE
        When you do that, you should see the map all by itself. That would tell you if it was an issue with your api key itself.
        If that works, double check the api key was copied right in the config section
        “api_key: ‘123456789’, // Your Bing maps api key”
        Let me know what you find
          Jeff
          @wscheer
          Okay your link with my API worked…
          I put my API key in the maproute.js file as the default key. Maybe that is the problem.
          How should the config.js file look?
          Like this?
                          latitude: '40.4406', // City latitude. Use google to get these coordinates
                          longitude: '-79.9959', // City longitude
                          map_zoom: '12', // 1 - 21
                          map_layer: 'TrafficFlow',
                          map_size: '500', // Using this for both length and width
                          api_key: 'xxxxx', // Your Bing maps api key
                          updateInterval: 300000 // 5 min refresh
          • W Offline
            wscheer @Jeff
            @Jeff yeah. Just replace the xxxx with your API key.
              Jeff @wscheer
              @wscheer
              That’s what I did.
              I really don’t know what’s going on.
              Maybe I should just implement it as a final picture
              • W Offline
                wscheer @Jeff
                @Jeff ok Jeff I have an idea.
                Can you look at your magic mirror page in server only mode again? Then if you right click and “inspect” the broken image you should see the url its trying to reach.
                Compare that to the url I had you copy paste in with your API that worked.
                Then if there is some sort of difference we should be able to track it down.
                  Jeff @wscheer
                  @wscheer
                  I found the mistake ;)
                  In your maproute.js it says “map_key” not “api_key”.
                  • W Offline
                    wscheer @Jeff
                    @Jeff omg I’m such a doof. I’ll go back in my previous post and fix that.
                    I’m so glad you got it working! I searched for months to find a map like this. I hope you enjoy it :)
                    • Z Offline
                      Zoltan @wscheer
                      @wscheer
                      My map is working and it shows the traffic. I however also have a map that don’t update and tried the Math.random() that you mentioned. The moment i add this to the line my map disappear completely which suggest i broke something. Do i interpret it wrong and can you please advise.
                      Like this the code is working fine:
                      wrapper.src = ‘http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/-26.0460,27.9790/13?mapSize=500,420&ml=TrafficFlow&key=Asm#####AJWIWc5o8Onf4fhH8O3IEe2e8ZcHaLTBWhx4_BWTvOW4S5xj60MuUJf4’;
                      Like this it isn’t working:
                      wrapper.src = ‘http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/-26.0460,27.9790/13?mapSize=500,420&pp=Math.random(),Math.random()&ml=TrafficFlow&key=Asm#####AJWIWc5o8Onf4fhH8O3IEe2e8ZcHaLTBWhx4_BWTvOW4S5xj60MuUJf4’;
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @Zoltan
                        @zoltan try the following:
                        wrapper.src = 'http://dev.virtualearth.net/REST/v1/Imagery/Map/Road/-26.0460,27.9790/13?mapSize=500,420&pp=' + Math.random() + ',' + Math.random() + '&ml=TrafficFlow&key=Asm#####AJWIWc5o8Onf4fhH8O3IEe2e8ZcHaLTBWhx4_BWTvOW4S5xj60MuUJf4';
                        This way you use the actual value and not Math.random() as a string.
                        Z 1 Reply Last reply Reply Quote 0
                        • 6
                        • 7
                        • 6 / 7
