    MMM-Profilepictures: problem with configuration
    5 Posts 2 Posters 2.6k Views 2 Watching
      Binog
      Hey snille
      Having trouble to set it up.
      Here is my config, and it throws up my config-file
      	module: "MMM-Profilepicture",
      	position: "fullscreen_below",
      	classes: "me",
      		opacity: "0.2",
      		maxWidth: 90%,
      		maxHeight: 90%,
      		url: "URL-to picture",
      The problem exists with the maxWidth/Height . There is no difference between 90% and “90%” so how is the correct spelling? if I set a // in front of those two lines my config-files does not throw up, but I don’t see the pictures.
      Can You help me, please?
        Binog
        How to send it to the correct bug-report for this module?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Binog
          @Binog it has to be in quotes
            Binog
            as said above,. it does not differ. that example was just the last try, thats why I posted it,… Figured out, that a “0.9” does not crash the config, but does neither work…
              @Binog 0.9 is not a valid value, you maybe want to check the property values section here https://www.w3schools.com/cssref/pr_dim_max-width.asp
