    Listening to only 127.0.0.1:8080...
    3 Posts 2 Posters 3.8k Views 2 Watching
    • SnilleS
      Snille Module Developer
      Hi all,
      At last update, it seams the MM only listens to 127.0.0.1:8080 if I have set [] in the ipWhitelist.
      Here is the “start” of the mirror:
      [STREAMING] Now streaming realtime logs for [all] processes
      0|mm       | Starting MagicMirror: v2.1.3-dev
      0|mm       | Loading config ...
      0|mm       | Loading module helpers ...
      0|mm       | Initializing new module helper ...
      All is starting ok and the mirror shows up on the local screen.
      But it’s not available from any other IP.
      The start of my conf…
      var config = {
              port: 8080,
              ipWhitelist: [],
              language: "sv",
              timeFormat: 24,
              units: "metric",
      And the listing ports (IPs) with netstat:
      pi@MagicMirror:~ $ netstat --tcp --listening --programs --numeric
      (Not all processes could be identified, non-owned process info
       will not be shown, you would have to be root to see it all.)
      Active Internet connections (only servers)
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
      tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      3486/electron.js
      ... (removed the other ports in the list) ...
      pi@MagicMirror:~ $
      As you can see it’s only listening on 127.0.0.1:8080…
      What have I missed/done?
      I can no longer access the /remote.html (for example) or any other “service” on the mirror from another machine.
      Best regards Snille
      If you cant find it, make it and share it
      MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
      • C
        Cato Module Developer
        It seems that you need to specify an IPv4 “address” in config, like this:
        var config = {
           ipWhitelist:  [],
           address: "0.0.0.0",
        Worked for me…
        SnilleS 1 Reply Last reply Reply Quote 2
        • SnilleS
          Snille Module Developer @Cato
          @Cato said in Listening to only 127.0.0.1:8080...:
          address: “0.0.0.0”,
          Ah! Thank you! :) Worked!
