    best acrylic sheet
    13 Posts 5 Posters 11.5k Views 5 Watching
    • A
      acdacd2
      Hello, I need to choose an acrylic sheet to build my mirror. What are your recommandations ?
      Thankx,
      • MichMichM
        MichMich
        Why do you need an acrylic sheet? As a mirror? I highly recommend real glass for this.
        • T
          tyho
          @MichMich it depend on the budget of course. Glas is more expensive or am i wrong?
          • MichMichM
            MichMich
            I think it will save you $30,- at most. On a ~ $250,- project, I think it’s not a smart thing to save money on, since it will highly affect the end result. I’d go for a cheaper monitor in that case …
            • MichMichM
              MichMich
              FYI: I paid €60,- for my 24" glass.
              T A 2 Replies Last reply Reply Quote 0
              • T
                tyho @MichMich
                @MichMich I have got a sample from pyrasied.nl and it looks really nice! a 24inch size glass cost less then 25 euro.
                But i still consider glass. Any recommendations for me?
                • MichMichM
                  MichMich
                  Just visit you local glass shop and discuss the possibilities. If they are a good shop they will help you finding the perfect piece of glass.
                  • A
                    acdacd2 @MichMich
                    @MichMich ok for glass but in Belgium I don’t find glass shop for two way mirror.
                    What are the spécifications required for the best result ?
                    Thankx
                    • A
                      acdacd2 @acdacd2
                      @acdacd2 how to choose ?
                      VERRE ANTIREFLET
                      VERRE RÉFLÉCHISSANT
                      MIROIR ESPION 1%, 12%, 20%
                      Spécifications de MIROIR ESPION
                      MIROIRS DIVISEURS
                      VERRE ISOLANT
                      MARQUAGE CE
                      luxar.ch>Produits>Verre réfléchissant>MIROIR ESPION 1%, 12%, 20%>Spécifications de MIROIR ESPION
                      SPÉCIFICATIONS DES MIROIRS ESPION
                      Particularités du miroir espion 1% :
                      Faible transmission lumineuse de 1%
                      Réflexion de la lumière côté verre/côté revêtement env. 43%/52% - fort effet miroir
                      La différence d’intensité lumineuse nécessaire est minime (1:5 lux)
                      Transmission des UV 0.5%
                      La couleur de la lumière reflétée est neutre
                      La couleur de la lumière transmise est jaune
                      Domaine d’utilisation: sécurité, architecture d’intérieur
                      Particularités du miroir espion 12% :
                      Transmission lumineuse moyenne de 12%
                      Réflexion de la lumière côté verre/côté revêtement env. 24%/46%
                      Transmission UV 8%
                      La couleur de la lumière transmise est neutre
                      Domaine d’utilisation: zones d’observation, concept d’éclairage, architecture d’intérieur
                      Particularités du miroir espion 20% :
                      Forte transmission lumineuse de 20%
                      Réflexion de la lumière côté verre/côté revêtement env. 24%/35%
                      La différence d’intensité lumineuse nécessaire est importante (1:10)
                      Transmission UV 18%
                      Domaine d’utilisation: murs multimédias, ameublement, architecture d’intérieur
                      Particularités du miroir espion 30% :
                      Forte transmission lumineuse de 30%
                      Réflexion de la lumière côté verre/côté revêtement env. 17%/29%
                      La différence d’intensité lumineuse nécessaire est importante (1:15)
                      Transmission UV 22%
                      Domaine d’utilisation : ameublement, architecture d’intérieur
                      Particularités du miroir espion 40% :
                      Forte transmission lumineuse de 40%
                      Réflexion de la lumière côté verre/côté revêtement env. 12%/23%
                      Transmission UV 28%
                      Domaine d’utilisation: ameublement, architecture d’intérieur
                      • C
                        CGabo
                        @acdacd2, les miroirs sans tain à 20% servent souvent à faire disparaître les moniteurs et affichages lorsqu’ils sont éteints.
                        Lorsqu’il est en fonction, le moniteur éclairé est visible derrière le miroir.
                        Avec 12% ou 20%, tu as les meilleurs résultats.
                        http://www.glastroesch.ch/fr/glas/Product/82-spionspiegel.html
                        Certains fournisseurs offrent également des modèles.
                        • A
                          acdacd2
                          bonjour,
                          merci pour ces infos,
                          Tu aurais un fournisseur,même hors belgique?
                          • MichMichM
                            MichMich
                            @evos The nearest glassshop around the corner.
                            • A
                              ashishtank Module Developer @MichMich
                              Hi @MichMich Thank you very much for this project. i am following this for many years and finally got some time to get my hands on this.
                              for a start i would like to start with smaller mirror but i am having difficulties getting it here in Netherlands (near Leiden). All the shops online are quite expensive. can you please tell me from where you got your mirror ?
