    MMM-Jarvis-Voice-Control
    27 Posts 10 Posters 31.6k Views 13 Watching
    • aro28A Offline
      aro28 @aro28
      @aro28
      Hello,
      Today i installed another mic thru the 3D sound card adapter and Setup Wizard has been completed successfully.
      But MM is running without animated circle. Also, when i run Jarvis in troubleshooting mode, in the beginning it introduces itself and when i say something it’s just repeating my words
      Should i configure something else? How do voice commands work here? I’m generally new to this.
      Thank you in advance.
      aro28A 1 Reply Last reply Reply Quote 1
      • aro28A Offline
        aro28 @aro28
        @aro28
        Hi any updates on above?
        What should to be installed first? MM or Jarvis?
        Thanks!
        • cowboysdudeC Offline
          cowboysdude Module Developer
          Clean it all out and reinstalled it…was good until Microsoft wanted a CC to register… that’s a big fat noooooooooooooooo…so this voice software will not do… ;)
          • N Offline
            nobita @merceaemil
            @merceaemil
            and to Anyone
            How to Connect (Usage) Jarvis in Magic Mirror
            such as How to open/close currentweather (Default module) ,
            How to open/close clock (default module)
            can you explain in detail becuase I,m Beginner
            Thanks for your kind
            • W Offline
              Waldehead
              Hello,
              although this thread is quite old, I have a question.
              Is it possible to display the inner circle (e.g. in blue) when Jarvis is in standby mode?
                aljosie @merceaemil
                @merceaemil give me the example/tutorial how to create of code how to jarvis can control homedevice, because i was try and get some failed
                  aljosie
                  Hallo @merceaemil i was installed the openjarvis plugin and mmm-jarvis-voice-control in my MM, but when i try to say anything the jarvis nothing to response, but when i say my hotword, jarvis can answer me, please help me.
