    Trouble with mm on start
    5 Posts 3 Posters 2.7k Views 3 Watching
    • F
      fasyr
      Hello I have a problem with my Magic mirror. To put mirror magic location I used a raspbian. I have deployed the Magic mirror on and use pm2 to launch it automatically. However I would like the startup of my Magic mirror to be done at the launch of my raspberry. In fact currently the raspbian desktop appears and then after a few seconds the Magic Mirror will display in turn.
      Could someone explain to me how to make the Magic mirror automatically launch without any configuration or desktop appearing at startup. Thank you for your help
      • U
        Ultimatum22 Module Developer
        A very fast solution is too remove all desktop icons and set a black background. I used a different desktop then the default to fix this issue. I might do a tutorial if more people want a cleaner solution.
        F 2 Replies Last reply Reply Quote 1
        • F
          fasyr @Ultimatum22
          @Ultimatum22
          Hello and thank you for your answer could you be more precise in the manipulations to do to set up this procedure because I am a beginner thank you again for your help
          • F
            fasyr @Ultimatum22
            @Ultimatum22
            Another thing I forgot. Is it possible to not display the configuration at the launch of raspberry. When I say configuration I’m talking about displaying the three raspberries and all the command line that activates the wifi ethernet card etc…
            link text
            Thx
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @fasyr
              @fasyr with the automatic installer those should be replaced with the magicmirror logo
              https://github.com/MichMich/MagicMirror/blob/master/splashscreen/splash.png
