    calendar *.ics file from local path
    9 Posts 4 Posters 13.2k Views 4 Watching
    • C Offline
      co8
      Is it possible to use in config.js file a calendar from e.g. /home/…/birthdays.ics or something alike?
      I tried various things, but nothing worked yet.
      Any sugestions?
      • MichMichM Offline
        MichMich
        Officially it’s not supported. There might be a workaround, but I can’t help you with that.
        Of course you can always just put the local file behind a simple webserver to feed it using an URL.
        • C Offline
          co8
          How should that look like?
          I tried it with my webserver on qnap nas. I copied the ics files into the web root folder and tried to access them as following
          https://serverip:8081/birthdays.ics
          but that didn’t work either.
          I couldn’t find a solution to access my owncloud calendars directly, so I have to extract them to a ics file and try to host them as that.
          • MichMichM Offline
            MichMich
            That should just work. Maybe there is an other issue with your calendar file or network.
            • C Offline
              co8
              Well, I can access them with firefox and it shows me to open or download them.
              But it won’t work with mm2.
                Shockwave
                @co8
                Yes, I got it working after a bit of experimenting. It wouldn’t read the ics file from other places like /MagicMirror which I assumed to be the root of the webserver.
                I created a new directory in /MagicMirror/modules, named birthdays, and placed by birthdays.ics file in there.
                Then in my config I added a 2nd calendar:
                					symbol: 'birthday-cake',
                					url: 'webcal://localhost:8080/modules/birthdays/birthdays.ics'
                • C Offline
                  co8
                  Thank you shockwave.
                  This works like a charm.
                  • C Offline
                    co8
                    How can I set the topic to solved?
                    • K Offline
                      KirAsh4 Moderator
                      I did it for you. For future reference, you will have to set the topic as a question first, then you can change it later to solved. On the bottom right of the posts, there are three dots in a vertical line. Click on that to change the topic to a question (which will mark it 'Unsolved'), then when you’re ready to change it, click on the three dots again and you’ll have an option to set it to 'Solved'.
