Error installing MagicMirror
I got following warnings during installation
npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint @^8.0.0 but none was installed
npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint @^8.0.0 but none was installed
npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint @^8.0.0 but none was installedUnmet peer dependency stylelint@^8.0.0
UNMET peer dependency stylelint@7.13.0npm WARN prefer global coffee-script@1.10.0 should be installed with -g
npm WARN prefer global jsonlint@1.6.2 should be installed with -g
npm WARN prefer global colorguard@1.2.0 should be installed with -g -
Hello,
Did you download the version:
RASPBIAN STRETCH WITH DESKTOP ?
I advise you to see this too: https://forum.magicmirror.builders/topic/4596/help-to-install-magicmirror
Good luck -
These are not errors but known warnings. What is your problem, doesn’t it work and what doesn’t work because this is probably not a blocking installation error.
