    Electron CPU usage
    247 Posts 46 Posters 629.8k Views 42 Watching
      schmo90
      hy i didnot turn off the hdmi,
      i will turn off the lcd with the gpio’s
      screen is turning on normal but electron browser is showing a black screen (mous appears at moving)
        binderth
        adding another flavour:
        As my Foscam FI9900P got an ONVIF-Update lately and is now capable of RTSP-streaming I installed MMM-RTSPStream.
        • activated fake (or full) OpenGL Desktop driver:
          omxplayer crashes
        • activated non-GL desktop driver:
          omxplayer runs
        So, as I see it, the omxplayer problem doesn’t concern MagicMirror - is there another way to reduce Electron CPU usage - except using an Open-GL dekstop driver?
        PS: activating fake KMS reduced CPU usage as recommended in this thread - but I’d like to have the video-stream of my cam on the MM (unfortunately it doesn’t provide MJPEG)
        • C Offline
          cdelaorden @binderth
          hi @binderth
          the fake-kms was created for keeping omxplayer compatibility but you need to add the “–no-osd” flag to the omxplayer command line
          you might want to try it
          dont bet on it, but changing line 101 of node_helper.js to
          var args = ["--no-osd", "--live", "--video_queue", "4", "--fps", "30",
          might do the trick
          • V Offline
            vinp Module Developer
            MM 2.4.1 - if anyone is trying to look for it while searching for forums. Apologies if it has already been stated
            So i’ve done it both ways:
            dtoverlay=vc4-kms-v3d
            I noticed that my CPU temp is well into the 60-70 degree Celsius with CPU loads mostly in the 1.x, 2.x, and sometimes 3.x ranges
            When i try the other way :
            dtoverlay=vc4-fkms-v3d
            CPU is much lower in temp under 50 degrees Celsius and CPU load rarely goes above 1.x
            and i am able to use the tvservice -o and tvservice -p to schedule my monitor to go on and off at certain times
            Hopefully this helps anyone searching for this issue on new installs like myself
            1 Reply Last reply Reply Quote 4
              jaffons
              So i ran into this issue as well. I started MM stuff 2-3 weeks ago.
              When everything was working my logs show:
              • I had the previous mm version ( probably 2.3.1)
              • Enable the Open GL driver, fake KMS (via raspi-config)
              • Disabling the screensaver https://www.raspberrypi.org/forums/viewtopic.php?t=57552
              • Autohiding the Mouse Pointer
              • rotate screen 270deg(CW), display_rotate=3 at /boot/config.txt
              • I also had the dtoverlay=vc4-fkms-v3d line there
              • I was getting this error though (thrunpm start ):
              libGL error: MESA-LOADER: failed to retrieve device information
              Anyway I messed something on my modules and had to reinstall the Raspbian. Same as before, Stretch 7/-18
              • Rotate screen at /boot/config.txt
              • installed the MM 2.4.1 and tried it straight away default config and modules. It was working alright
              • I think I added the dtoverlay=vc4-fkms-v3d line…
                • and boom animations started lagging (+high CPU)
                • also npm start dev didnt work. It launched but no mirror was shown and if i had mm running it would stop refreshing.
              Any way I figured out that taking that commenting out that # dtoverlay=vc4-fkms-v3d everything works flawlessy. I dont get the “libGL”-error
              and I also updated npm 5.6.0 → 6.2.0 sudo npm i -g npm and npm start dev started working (dev or no dev).
              My Rpi temperature is under 50C when mm is running (no heatsink).
              Hope this helps out someone!
              A 1 Reply Last reply Reply Quote 4
                adamlove86 @jaffons
                @vinp and @jaffons WOW! Thank you for your comments… Made a huge difference.
                After some months I needed to reinstall from scratch (now also hosting octoprint and a remote desktop simultaneously). I thought MM animations were just generally slow, but this made a huge difference compared to the more orthodox setup.
                I don’t see why this configuration shouldn’t be preferred over the normal Pi configuration, and the OpenGL driver was also much trickier to get working.
                • K Offline
                  Knapoc
                  Is it just me, that after the most recent rpi firmware update display_rotate/display_hdmi_rotate is not working with the fkms driver?
                  I found the following in the official documentation:
                  If using the VC4 FKMS V3D driver (this is the default on the Raspberry Pi 4), then 90 and 270 degree rotations are not supported. The Screen Configuration utility provides display rotations for this driver.
                  Unfortunately I have no clue how to run the screen configuration utility. There’s always a black screen even if I run pm2 stop mm.
                  • 9
                  • 10
                  • 11
                  • 12
                  • 13
                  • 13 / 13
